跳转到主内容
加入维修社区 - 创建账户
PlayStation 2 Slimline SCPH-7500x Fan Replacement
你所需要的
    • Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
  1. PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 2 中的图像 1,1
    • Locate the six feet on the bottom of the PS2.
    • Five of these feet are in plain sight while the last foot is located under the black void sticker on the back of the device.
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or the screw should be in plain sight.
  2. PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 3 中的图像 1,3 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 3 中的图像 2,3 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 3 中的图像 3,3
    • Remove the five visible feet from the bottom of the device using a spudger.
  3. PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 4 中的图像 1,2 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 4 中的图像 2,2
    • Remove the sticker and then remove the 6th foot.
  4. PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 5 中的图像 1,3 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 5 中的图像 2,3 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 5 中的图像 3,3
    • After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
  5. PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 6 中的图像 1,3 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 6 中的图像 2,3 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 6 中的图像 3,3
    • Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
    • You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
  6. PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 7 中的图像 1,1
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
  7. PlayStation 2 Slimline SCPH-7500x Fan Replacement, Fan: 步骤 8 中的图像 1,3 PlayStation 2 Slimline SCPH-7500x Fan Replacement, Fan: 步骤 8 中的图像 2,3 PlayStation 2 Slimline SCPH-7500x Fan Replacement, Fan: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    • Locate the fan component of the motherboard of the PS2.
    • With your fingers or tweezers, peel off the sticker that holds down the fan's wiring.
  8. PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 9 中的图像 1,2 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 9 中的图像 2,2
    • Detach the terminal (white covering) to the red and yellow cords from the motherboard to the fan with the use of tweezers.
  9. PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 10 中的图像 1,2 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 步骤 10 中的图像 2,2
    • Locate and unscrew the three 1.6mm screws located next to the base of the fan.
    • They are located off the curved edge of the fan.
    • Once you have removed the three screws, you are able to remove the fan from the PS2.
结论
5等其他人完成本指南。
Jared Hirata
于04/09/13注册
1,010 声望
创作了7篇指南
团队
Cal Poly, Team 17-4, Regan Spring 2013 Cal Poly, Team 17-4, Regan Spring 2013 的会员
CPSU-REGAN-S13S17G4
3 名成员
创作了30篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 82
总计 5,080
