简介
This guide will walk you through step-by-step on how to properly remove and install the clock battery in the PlayStation 2 Slimline.
配件
没有特定配件。
Turn off the PlayStation 2 (or PS2) and carefully unplug from the power source. Check to see there are no discs inside the console before flipping the game system upside-down.
Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
3等其他人完成本指南。
一条评论
These instructions take for granted how the battery itself should be replaced. I imagine you reconnect the contact with the red wire to the positive side of the CR2032 battery and the contact for the black wire to the negative and wrap electrical tape around the entire thing BEFORE reconnecting it and then following these instructions in reverse order.
