跳转到主内容
PlayStation 2 Slimline Optical Drive Replacement
你所需要的
  1. PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,3 PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 2,3 PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 3,3
    • Remove the rubber feet on two of the screw covers on the bottom of the console.
    • Remove the screw covers and the screws themselves.
    • Caution: One of the screws is underneath the "Do not void" seal
  2. PlayStation 2 Slimline Optical Drive Replacement: 步骤 2 中的图像 1,2 PlayStation 2 Slimline Optical Drive Replacement: 步骤 2 中的图像 2,2
    • If all screws are removed.
    • Use a metal spunger to open the chassis
  3. PlayStation 2 Slimline Optical Drive Replacement: 步骤 3 中的图像 1,3 PlayStation 2 Slimline Optical Drive Replacement: 步骤 3 中的图像 2,3 PlayStation 2 Slimline Optical Drive Replacement: 步骤 3 中的图像 3,3
    • Slip the three cables out of the sockets.
    • Use a PH01 screwdriver to remove the four screws securing the optical drive
    • Lift up the optical drive and remove the duct tape under the flex cable.
    • Now the optical drive is free and ready for replacement
结论
16等其他人完成本指南。
tlroesner
于05/13/12注册
1,864 声望
创作了4篇指南
3条评论
How is it that this guide says difficult and the other PS2 drive replacement on here says easy?
Mark - 回复
it really depends on your level of skill/experience.
Damien Simons -
How many different versions of drive is there for the slim model? When you go to replace it, do you just compare the model number on the laser?
Trevor V - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 93
总计 22,082
