跳转到主内容
PlayStation 2 Slimline Fan Replacement
你所需要的
  1. PlayStation 2 Slimline Fan Replacement, Outer Shell: 步骤 1 中的图像 1,1
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline Fan Replacement: 步骤 2 中的图像 1,3 PlayStation 2 Slimline Fan Replacement: 步骤 2 中的图像 2,3 PlayStation 2 Slimline Fan Replacement: 步骤 2 中的图像 3,3
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline Fan Replacement: 步骤 3 中的图像 1,3 PlayStation 2 Slimline Fan Replacement: 步骤 3 中的图像 2,3 PlayStation 2 Slimline Fan Replacement: 步骤 3 中的图像 3,3
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline Fan Replacement: 步骤 4 中的图像 1,3 PlayStation 2 Slimline Fan Replacement: 步骤 4 中的图像 2,3 PlayStation 2 Slimline Fan Replacement: 步骤 4 中的图像 3,3
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline Fan Replacement, Fan: 步骤 5 中的图像 1,2 PlayStation 2 Slimline Fan Replacement, Fan: 步骤 5 中的图像 2,2
    • Locate the fan at the front, left section of the unit.
  6. PlayStation 2 Slimline Fan Replacement: 步骤 6 中的图像 1,2 PlayStation 2 Slimline Fan Replacement: 步骤 6 中的图像 2,2
    • Peel off the sticker holding the power cords to the unit.
  7. PlayStation 2 Slimline Fan Replacement: 步骤 7 中的图像 1,2 PlayStation 2 Slimline Fan Replacement: 步骤 7 中的图像 2,2
    • Lift the connector from the motherboard with a pair of tweezers using a firm, upward force.
  8. PlayStation 2 Slimline Fan Replacement: 步骤 8 中的图像 1,3 PlayStation 2 Slimline Fan Replacement: 步骤 8 中的图像 2,3 PlayStation 2 Slimline Fan Replacement: 步骤 8 中的图像 3,3
    • Remove all three 1.6 mm screws fastening the fan to the unit using a #1 Phillips screwdriver.
    • Gently lift and remove the fan from its compartment.
结论
10等其他人完成本指南。
Thomas Sullivan
于10/23/13注册
3,927 声望
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 30
过去 30 天: 98
总计 8,311
