跳转到主内容
PlayStation 2 Slimline Clock Battery Replacement
你所需要的
  1. PlayStation 2 Slimline Clock Battery Replacement, Outer Shell: 步骤 1 中的图像 1,1
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline Clock Battery Replacement: 步骤 2 中的图像 1,3 PlayStation 2 Slimline Clock Battery Replacement: 步骤 2 中的图像 2,3 PlayStation 2 Slimline Clock Battery Replacement: 步骤 2 中的图像 3,3
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline Clock Battery Replacement: 步骤 3 中的图像 1,3 PlayStation 2 Slimline Clock Battery Replacement: 步骤 3 中的图像 2,3 PlayStation 2 Slimline Clock Battery Replacement: 步骤 3 中的图像 3,3
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline Clock Battery Replacement: 步骤 4 中的图像 1,3 PlayStation 2 Slimline Clock Battery Replacement: 步骤 4 中的图像 2,3 PlayStation 2 Slimline Clock Battery Replacement: 步骤 4 中的图像 3,3
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline Clock Battery Replacement, Clock Battery: 步骤 5 中的图像 1,1
    • Locate the clock battery at the front, right section of the unit. The battery has a circular shape with red (+) and black (-) wires connecting to the motherboard.
  6. PlayStation 2 Slimline Clock Battery Replacement: 步骤 6 中的图像 1,2 PlayStation 2 Slimline Clock Battery Replacement: 步骤 6 中的图像 2,2
    • Lift the connector from the motherboard with a pair of tweezers using a firm, upward force.
  7. PlayStation 2 Slimline Clock Battery Replacement: 步骤 7 中的图像 1,2 PlayStation 2 Slimline Clock Battery Replacement: 步骤 7 中的图像 2,2
    • Gently lift and remove the battery from its compartment using a spudger.
结论
13等其他人完成本指南。
Thomas Sullivan
于10/23/13注册
3,927 声望
创作了6篇指南
10条评论
Ich wollte die Batterie wechseln, aber bei meiner PS2 Slim ist an der Stelle der Stecker des Laufwerkes fest? Und ich kann weit und breit keine Batterie entdecken. Weiß jemand warum das so ist? Gibt es verschiedene Revisionen, so dass die Batterie noch woanders sitzen könnte?
Lupo - 回复
So for anybody stumbling across this in recent times: the newer revisions (starting with SCPH-7700x?) have a standard CR2032 coincell battery holder on the mainboard and not this custom wired battery. In order to get to the battery holder on the mainboard, the console must be disassembled further. See the mainboard guide here on iFixIt on how to do that.
Philipp -
This does not explain how to get the battery out of the black plastic, replace it, and put the wires back. That's the most important part!
Patrick Lewis - 回复
I believe that is because the clock battery is sold as a single unit. So there is no way to replace the actual battery inside.
Shahyah Darioosh -
Yeah, the battery’s a special-made CR2032 with two leads spot-welded onto the contact surfaces. You see it if you carefully remove the heat-shrink. Don’t EVER try to spot-weld or solder onto a lithium battery yourself. Just type “cr2032 cmos” or “cr2032 with leads” into your favorite parts store’s search bar. It should cost between three and ten us dollars. Keep the original, as you may need to salvage the original wired connector—these are made for a wide variety of (mostly-dell-laptop) applications, so the new battery will likely have a slightly different connector. If that’s the case, clip the original wires as near to where they connect to the battery as possible. Then, splice the original battery’s connector onto the new battery’s leads while maintaining polarity and remembering to insulate any bare wire that remains. Just tightly loop any excess wire after plugging the replacement in. Use a little strip of masking tape if you’re concerned about chassis pinching.
Allen Smith -
Absolutely! It's so much easier to do on the PlayStation 2 Big Unit. You just take the battery out and replace it it's simple. It just lifts out like a watch battery on The Big Unit. I thought this was going to be about the same but it is quite different.
markbrunk -
Ist das die Playstation 2 Slim DHCP 90004 ??! Sitzt bei der 90004 die Batterie auf dem Mainboard ( Motherboard zum einklinken ?!! ) oder so wir in der Anleitung beschrieben mit einem 2 pol Stecker im Gehäuse ??!
Bitte um antwort. Gruß Holger
Holger Elbing - 回复
km*?)”)”)”)”)”)*9£83646491)2+£82828228229
Istadad Jamshaid - 回复
km*?)”)”)”)”)”)*9£83646491)2+£82828228229wowoosekskaoso
Hola, se me ha doblado un pin al hacerlo,lo he vuelto a poner bien pero se me ha partido un cachito de la pared de plástico amarilla donde va el enchufado la pila,funciona bien pero por el pin doblado o por el plástico roto hay algún riesgo?
Isaac Gomez Ferrer - 回复
添加评论
浏览统计数据:
过去 24 小时: 24
过去 7 天: 197
过去 30 天: 701
总计 41,020
