1. Remove all five screws on the downside of the PS2 Slimline Remove the "Do not void" seal carefully, underneath is the fifth screw located. Remove the "Do not void" seal carefully, underneath is the fifth screw located.
    • Remove all five screws on the downside of the PS2 Slimline
    • Remove the "Do not void" seal carefully, underneath is the fifth screw located.
  2. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  3. Make sure all screws are removed Caution with the seal, do not forget.
    • Make sure all screws are removed
    • Caution with the seal, do not forget.
    • Then take a metal sponger and open the chassis
  4. Locate the battery on the motherboard Use a metal spunger to peel it up Pull the cable and the battery is removed, ready to replace
    • Locate the battery on the motherboard
    • Use a metal spunger to peel it up
    • Pull the cable and the battery is removed, ready to replace
结论
4等其他人完成本指南。
tlroesner
于2012年05月13日注册
1,788 信誉积分
创作了4篇指南
浏览统计数据:
过去的24小时: 2
过去的7天: 10
过去的30天: 33
总计 8,341
