跳转到主内容
PlayStation 2 Optical Disc Drive Lens Cleaning
你所需要的
  1. PlayStation 2 Optical Disc Drive Lens Cleaning, Top Cover: 步骤 1 中的图像 1,3 PlayStation 2 Optical Disc Drive Lens Cleaning, Top Cover: 步骤 1 中的图像 2,3 PlayStation 2 Optical Disc Drive Lens Cleaning, Top Cover: 步骤 1 中的图像 3,3
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
  2. PlayStation 2 Optical Disc Drive Lens Cleaning: 步骤 2 中的图像 1,1
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
  3. PlayStation 2 Optical Disc Drive Lens Cleaning: 步骤 3 中的图像 1,1
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
  4. PlayStation 2 Optical Disc Drive Lens Cleaning: 步骤 4 中的图像 1,2 PlayStation 2 Optical Disc Drive Lens Cleaning: 步骤 4 中的图像 2,2
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
  5. PlayStation 2 Optical Disc Drive Lens Cleaning, PlayStation 2 Optical Disc Drive Lens Cleaning: 步骤 5 中的图像 1,2 PlayStation 2 Optical Disc Drive Lens Cleaning, PlayStation 2 Optical Disc Drive Lens Cleaning: 步骤 5 中的图像 2,2
    • Remove the four 6.4 mm Phillips screws securing the top lid of the optical disc drive.
    • Lift and remove the lid from the optical disc drive.
  6. PlayStation 2 Optical Disc Drive Lens Cleaning: 步骤 6 中的图像 1,1
    • Carefully wipe the lens in a circular motion with a rubbing alcohol damped Q-Tip.
    • Do not over-dampen the Q-Tip with rubbing alcohol.
    • Allow a few minutes for the rubbing alcohol to evaporate.
结论
58等其他人完成本指南。
emessers
于10/28/09注册
2,571 声望
撰写一个指南
团队
Cal Poly, Team 19-1, Maness Fall 2009 Cal Poly, Team 19-1, Maness Fall 2009 的会员
CPSU-MANESS-F09S19G1
4 名成员
创作了34篇指南
9条评论
I've tried the steps mentioned above to no avail. The problem persist. Anything else i can do besides purchasing another console? Sentimental value.Thank you.
Albie - 回复
What I'm gonna try and do is take a laser from a PC DVD burner tray and see if I reads things. It's a long shot but you can't break what's already broken ehh. I'll let you know what happens. And if it works I will write the proper tutorial for it:)
Yuri weinberg -
HOw to use a lens cleaner dvd in Ps2
sajidsahito110 - 回复
please answer my problem
sajidsahito110 - 回复
Hi
I have problem with my ps2 when I put the cd in the screen says that it's reading the cd but after a few minutes it stops and says no data.
What should I do ? how do I fix it ? And any clues on what to do?
Arif Ali - 回复
添加评论
浏览统计数据:
过去 24 小时: 33
过去 7 天: 262
过去 30 天: 1,202
总计 96,134
