跳转到主内容
PlayStation 2 Disc Tray Belt Replacement
你所需要的
  1. PlayStation 2 Disc Tray Belt Replacement, Remove the disk dirver: 步骤 1 中的图像 1,2 PlayStation 2 Disc Tray Belt Replacement, Remove the disk dirver: 步骤 1 中的图像 2,2
    • Open the console case and remove the disk driver.
    • Be careful with the flat cables and its connectors.
  2. PlayStation 2 Disc Tray Belt Replacement, Remove the protection: 步骤 2 中的图像 1,3 PlayStation 2 Disc Tray Belt Replacement, Remove the protection: 步骤 2 中的图像 2,3 PlayStation 2 Disc Tray Belt Replacement, Remove the protection: 步骤 2 中的图像 3,3
    • Remove the disk tray and remove the gear plastic conver protection.
    • You dont need to remove any gear form its place.
    • Remove the old belt and replace with a new one.
    • The belt must be a PS2 fat compatible belt. If you don't have a PS2 you can use a radio K7 driver belt but it need to have the same diameter of the PS2 belt.
    • Old and lax belt.
    • Brand new belt.
  3. PlayStation 2 Disc Tray Belt Replacement, Clean the lens: 步骤 3 中的图像 1,1
    • Don't loose the opportunity and clean the laser lens with a cotton swab.
终点
5等其他人完成本指南。
3条评论
Anyone has the measurements of this belt? What’s the thickness and what’s the diameter or circumference?
Joel - 回复
I head 40mm diameter and 1,2mm thickness should fit fine.
Markus Ro -
Anyone has the dimensions of this belt?
What’s the circumference/radius? What’s the thickness?
Joel - 回复
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 121
过去 30 天: 558
总计 7,032
