跳转到主内容
PlayStation 2 Disc Drive Replacement
你所需要的
视频概述
  1. PlayStation 2 Disc Drive Replacement, Top Cover: 步骤 1 中的图像 1,3 PlayStation 2 Disc Drive Replacement, Top Cover: 步骤 1 中的图像 2,3 PlayStation 2 Disc Drive Replacement, Top Cover: 步骤 1 中的图像 3,3
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
  2. PlayStation 2 Disc Drive Replacement: 步骤 2 中的图像 1,1
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
  3. PlayStation 2 Disc Drive Replacement: 步骤 3 中的图像 1,1
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
  4. PlayStation 2 Disc Drive Replacement: 步骤 4 中的图像 1,2 PlayStation 2 Disc Drive Replacement: 步骤 4 中的图像 2,2
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
  5. PlayStation 2 Disc Drive Replacement, Power Board: 步骤 5 中的图像 1,2 PlayStation 2 Disc Drive Replacement, Power Board: 步骤 5 中的图像 2,2
    • Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case.
    • Lift and remove the optical disc drive straight up out of the bottom case.
  6. PlayStation 2 Disc Drive Replacement: 步骤 6 中的图像 1,2 PlayStation 2 Disc Drive Replacement: 步骤 6 中的图像 2,2
    • Remove the two 14.6 mm gold-headed Phillips securing the controller ports to the bottom case.
  7. PlayStation 2 Disc Drive Replacement: 步骤 7 中的图像 1,2 PlayStation 2 Disc Drive Replacement: 步骤 7 中的图像 2,2
    • Gently lift the controller port board out of its recess within the bottom case.
    • Do not completely remove the controller port board. It is still attached via a ribbon cable.
    • Pull the controller port ribbon cable straight away from its socket on the controller port board.
    • Remove the controller port board out of the bottom case.
  8. PlayStation 2 Disc Drive Replacement: 步骤 8 中的图像 1,1
    • Remove the two 14.6 mm gold Phillips screws securing the fan to the bottom case.
  9. PlayStation 2 Disc Drive Replacement: 步骤 9 中的图像 1,1
    • If there is a device occupying the expansion bay, make sure to remove the device. The expansion base should be empty.
    • Pry and remove the expansion bay cover away from its posts on the bottom case.
  10. PlayStation 2 Disc Drive Replacement: 步骤 10 中的图像 1,1
    • Lift the motherboard assembly from its front edge and remove it from the lower case.
  11. PlayStation 2 Disc Drive Replacement: 步骤 11 中的图像 1,1
    • Now that all of that bulky plastic is out of the way, we can get to the fun stuff - electronics!
    • Remove the four 7.6 mm gold-head Phillips securing the power supply to the motherboard assembly.
  12. PlayStation 2 Disc Drive Replacement: 步骤 12 中的图像 1,1
    • Lift the expansion bay cage up off the motherboard assembly.
  13. PlayStation 2 Disc Drive Replacement: 步骤 13 中的图像 1,2 PlayStation 2 Disc Drive Replacement: 步骤 13 中的图像 2,2
    • Do not remove the power board yet. It is still attached to the motherboard assembly via the power board connector (highlighted in the first picture), which is located next to the main power switch.
    • Carefully lift the power board. You should now see the power board connector attached to the power board.
    • Pull the power board connector straight to lift it out of its socket on the power board.
  14. PlayStation 2 Disc Drive Replacement, Disc Drive: 步骤 14 中的图像 1,1
    • Underneath where the power supply once was is a transparent piece of plastic. This is the heat shield, and it can now be removed.
    • It can be a bit stubborn, so it may take a little finessing to get it free.
  15. PlayStation 2 Disc Drive Replacement: 步骤 15 中的图像 1,2 PlayStation 2 Disc Drive Replacement: 步骤 15 中的图像 2,2
    • Now with the heat shield out of the way, you can see there are quite a few screws holding the rest in place.
    • Remove the following screws securing the metal chassis to the logic board:
    • Seven 5.8 mm Phillips silver screws.
    • Two 7.4 mm Phillips gold screws.
  16. PlayStation 2 Disc Drive Replacement: 步骤 16 中的图像 1,3 PlayStation 2 Disc Drive Replacement: 步骤 16 中的图像 2,3 PlayStation 2 Disc Drive Replacement: 步骤 16 中的图像 3,3
    • Unclip flaps, one on one side and two on the other, holding the disc drive together. The first two pictures display where the three flaps are. This is very tricky so take your time.
    • Carefully begin to lift out the disc drive.
    • Beware, there are ribbon cables still attached.
  17. PlayStation 2 Disc Drive Replacement: 步骤 17 中的图像 1,3 PlayStation 2 Disc Drive Replacement: 步骤 17 中的图像 2,3 PlayStation 2 Disc Drive Replacement: 步骤 17 中的图像 3,3
    • There are four ribbon cables attached to the disc drive. Be careful not to rip any of them!
    • Remove the three blue ribbon cables and one orange ribbon cable by gently pulling on the blue plastic strips.
    • Carefully remove the orange ribbon cable from the laser by gently pulling on the white plastic strip.
    • Now the disc drive is free to be removed.
结论
44等其他人完成本指南。
jwyoung
于11/04/09注册
2,587 声望
创作了5篇指南
团队
Cal Poly, Team 19-1, Maness Fall 2009 Cal Poly, Team 19-1, Maness Fall 2009 的会员
CPSU-MANESS-F09S19G1
4 名成员
创作了34篇指南
4条评论
It helped out a lot I was able to fix my
David Sharp - 回复
What replacement drive would you recommend?
Steve Bennett - 回复
How do you know if the DVD drive is a 3 watt or 5 watt?
Robert Goetsch - 回复
Are there any "New" DVD drives we could buy?
Christopher - 回复
添加评论
浏览统计数据:
过去 24 小时: 46
过去 7 天: 315
过去 30 天: 1,394
总计 103,604
