简介
Nuance Dragon Plantronics Calisto B70 or Plantronics Calisto Pro B70 are used as examples here: “Make your Dragon listen to you again”.
Disclaimer: All work and opening of the equipment is on your own responsibility and risk!
After 10 years of use, the battery does not last long enough. A new battery and some skilled work on the delicate device end up with a fully functioning headset again.
你所需要的
The red markings show the positions of breaking/fixing points inside the case, which are slightly glued. Nevertheless, the case can be opened without too much damage using a small, sharp screwdriver. The fix at the back of the headset at position 1 is clipped inside the case, rather than glued (see clip at steps 4 and 11).
If the power connector is glued into the case, then de-soldering it is the easiest solution. If it is not glued, then de-soldering is not necessary.
Exchange the battery with the new replacement.
The replacement battery in the picture worked perfectly for the Plantronics B70.
Cut and prepare the replacement battery cables for soldering.
Solder the new battery to plus (red cable) and minus (black cable).
Fix the new battery onto the foam and place it in the center of the position, which is marked by a white line.
Carefully put everything back into position. Re-solder the power connector, if it had to be de-soldered before. Fix it back into the round hole.
Close the case with the clip 1. The black and silver case can be fixed best using some transparent tape around the case.
Test loading the new battery as usual.
另外一个人完成了本指南。
