本指南有最近更改,您可查看未经巡查的最新版本。
简介
The following steps will teach you how to disassemble your headset and install a new microphone.
你所需要的
Flip the headset face down.
Squeeze both sides of the battery cover.
While squeezing, pull the cover up slowly to remove it.
Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components.
Apply additional heat at the tip of the microphone.
即将完成!
To reassemble your device, follow these instructions in reverse order. Replace the glue and solder where they are needed.
结论
