跳转到主内容
Plantronics CS50 Headset Battery Replacement
你所需要的
  1. Plantronics CS50 Headset Battery Replacement, Battery: 步骤 1 中的图像 1,3 Plantronics CS50 Headset Battery Replacement, Battery: 步骤 1 中的图像 2,3 Plantronics CS50 Headset Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip the headset face down.
    • Squeeze both sides of the battery cover.
    • While squeezing, pull the cover up slowly to remove it.
  2. Plantronics CS50 Headset Battery Replacement: 步骤 2 中的图像 1,3 Plantronics CS50 Headset Battery Replacement: 步骤 2 中的图像 2,3 Plantronics CS50 Headset Battery Replacement: 步骤 2 中的图像 3,3
    • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
结论
To reassemble your device, follow these instructions in reverse order
2等其他人完成本指南。
团队
Cal Poly, Team 17-29, Amido Spring 2012 Cal Poly, Team 17-29, Amido Spring 2012 的会员
CPSU-AMIDO-S12S17G29
4 名成员
创作了7篇指南
2指南评论
I created the article https://de.ifixit.com/Artikel/Battery_Pl... for a Silvercrest bluetooth transmitter, but I was not able to change the needed parts of this howto to link to that article.
anton2 - 回复
I replaced the battery with a new battery, I cleaned all the connectors and I reset the base and the headset is still not working
Lee kathryn lucas - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 7,951
