跳转到主内容
Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement
你所需要的
  1. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Grip: 步骤 1 中的图像 1,2 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Grip: 步骤 1 中的图像 2,2
    • Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
  2. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: 步骤 2 中的图像 1,2 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: 步骤 2 中的图像 2,2
    • Pull the grip away from the frame.
  3. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: 步骤 3 中的图像 1,2 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: 步骤 3 中的图像 2,2
    • Pull the grip through the opening.
    • The grip is connected in the middle and is one piece.
  4. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Macroline: 步骤 4 中的图像 1,3 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Macroline: 步骤 4 中的图像 2,3 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Macroline: 步骤 4 中的图像 3,3
    • Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
    • It helps to rotate the collar to create room to pull out macroline.
  5. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: 步骤 5 中的图像 1,3 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: 步骤 5 中的图像 2,3 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: 步骤 5 中的图像 3,3
    • While pulling in the metal ring on the fitting, pull the macroline out.
  6. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Body: 步骤 6 中的图像 1,3 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Body: 步骤 6 中的图像 2,3 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Body: 步骤 6 中的图像 3,3
    • Use 1/8" allen wrench to remove screw behind regulator.
  7. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: 步骤 7 中的图像 1,3 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: 步骤 7 中的图像 2,3 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: 步骤 7 中的图像 3,3
    • Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
    • The screw only needs to be turned a couple of times.
    • Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
    • BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
  8. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid: 步骤 8 中的图像 1,3 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid: 步骤 8 中的图像 2,3 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid: 步骤 8 中的图像 3,3
    • Using the Phillips #0 screwdriver, remove the 2 screws in the solenoid.
    • Remove the solenoid.
  9. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: 步骤 9 中的图像 1,1
    • Pry the board connection with the 2 black wires from the terminal.
    • BE CAREFUL: Do not pull hard by the wires or you may dislodge them from the connection instead of removing the connection from the board.
    • Pull out the wires through the opening in the top of the grip and replace the solenoid.
  10. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid Gasket: 步骤 10 中的图像 1,3 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid Gasket: 步骤 10 中的图像 2,3 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid Gasket: 步骤 10 中的图像 3,3
    • Locate the solenoid gasket manifold, underneath the top half of the body.
  11. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: 步骤 11 中的图像 1,3 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: 步骤 11 中的图像 2,3 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: 步骤 11 中的图像 3,3
    • Remove the solenoid gasket manifold by applying pressure with one finger to the part closest to the end of the barrel.
结论
Rett Triplett
于10/18/13注册
801 声望
创作了8篇指南
团队
Clemson, Team 13-6, Benson Fall 2013 Clemson, Team 13-6, Benson Fall 2013 的会员
CLEM-BENSON-F13S13G6
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 593
