跳转到主内容
Planet Eclipse Etha Trigger Replacement
你所需要的
  1. Planet Eclipse Etha Trigger Replacement, Battery and Grip Panels: 步骤 1 中的图像 1,2 Planet Eclipse Etha Trigger Replacement, Battery and Grip Panels: 步骤 1 中的图像 2,2
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  2. Planet Eclipse Etha Trigger Replacement: 步骤 2 中的图像 1,1
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  3. Planet Eclipse Etha Trigger Replacement: 步骤 3 中的图像 1,2 Planet Eclipse Etha Trigger Replacement: 步骤 3 中的图像 2,2
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  4. Planet Eclipse Etha Trigger Replacement, Trigger: 步骤 4 中的图像 1,1
    • Use a hex key to unscrew the middle screw on the top of the trigger.
  5. Planet Eclipse Etha Trigger Replacement: 步骤 5 中的图像 1,1
    • Use same hex key to push through trigger retention pin on the side of the gun.
  6. Planet Eclipse Etha Trigger Replacement: 步骤 6 中的图像 1,2 Planet Eclipse Etha Trigger Replacement: 步骤 6 中的图像 2,2
    • Pull out the trigger by grabbing the bottom and slowly rotating outwards.
结论
另外一个人完成了本指南。
Evan Hench
于10/19/14注册
211 声望
撰写一个指南
团队
Cal Poly, Team 10-42, Amido Fall 2014 Cal Poly, Team 10-42, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G42
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 941
