跳转到主内容
Planet Eclipse Etha Bolt O-rings Replacement
你所需要的
  1. Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: 步骤 1 中的图像 1,3 Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: 步骤 1 中的图像 2,3 Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: 步骤 1 中的图像 3,3
    • Using the 1/4" hex key, turn the bolt counterclockwise and remove.
  2. Planet Eclipse Etha Bolt O-rings Replacement: 步骤 2 中的图像 1,2 Planet Eclipse Etha Bolt O-rings Replacement: 步骤 2 中的图像 2,2
    • Slide the bolt tip and spring off of the main assembly.
    • Keep a towel handy, you may get some grease on your hands.
  3. Planet Eclipse Etha Bolt O-rings Replacement: 步骤 3 中的图像 1,3 Planet Eclipse Etha Bolt O-rings Replacement: 步骤 3 中的图像 2,3 Planet Eclipse Etha Bolt O-rings Replacement: 步骤 3 中的图像 3,3
    • Unscrew the casing from the rest of the bolt.
    • Again, you may get some grease on your hands during this step.
  4. Planet Eclipse Etha Bolt O-rings Replacement: 步骤 4 中的图像 1,3 Planet Eclipse Etha Bolt O-rings Replacement: 步骤 4 中的图像 2,3 Planet Eclipse Etha Bolt O-rings Replacement: 步骤 4 中的图像 3,3
    • Grab the flat surface shown.
    • Unscrew this portion counter clockwise to remove it.
    • If you're having trouble unscrewing the part, try using a small wrench.
  5. Planet Eclipse Etha Bolt O-rings Replacement: 步骤 5 中的图像 1,2 Planet Eclipse Etha Bolt O-rings Replacement: 步骤 5 中的图像 2,2
    • Grab the threaded cover and slide it away from the spring.
    • The bolt should now be in three pieces.
    • The threaded cover is the same part that you unscrewed in the last step.
  6. Planet Eclipse Etha Bolt O-rings Replacement: 步骤 6 中的图像 1,3 Planet Eclipse Etha Bolt O-rings Replacement: 步骤 6 中的图像 2,3 Planet Eclipse Etha Bolt O-rings Replacement: 步骤 6 中的图像 3,3
    • Replace and lubricate the 9 marked O-rings.
    • O-ring removal will be explained in the next step.
  7. Planet Eclipse Etha Bolt O-rings Replacement: 步骤 7 中的图像 1,3 Planet Eclipse Etha Bolt O-rings Replacement: 步骤 7 中的图像 2,3 Planet Eclipse Etha Bolt O-rings Replacement: 步骤 7 中的图像 3,3
    • Grab the O-ring on the sides.
    • Pinch the O-ring upwards to create a gap between the metal and the ring.
    • Use a small object to slip into the loop and pull the O-ring off gently.
    • We recommend using a small Allen Key for this.
结论
另外一个人完成了本指南。
nicholasj6
于10/14/14注册
261 声望
创作了2篇指南
团队
Cal Poly, Team 10-42, Amido Fall 2014 Cal Poly, Team 10-42, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G42
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 28
总计 2,182
