跳转到主内容
Pioneer Steel Wheels Headphone Headband Replacement
你所需要的
  1. Pioneer Steel Wheels Headphone Headband Replacement, Headband: 步骤 1 中的图像 1,2 Pioneer Steel Wheels Headphone Headband Replacement, Headband: 步骤 1 中的图像 2,2
    • Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
  2. Pioneer Steel Wheels Headphone Headband Replacement: 步骤 2 中的图像 1,2 Pioneer Steel Wheels Headphone Headband Replacement: 步骤 2 中的图像 2,2
    • With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
    • With force, pull upwards.
  3. Pioneer Steel Wheels Headphone Headband Replacement: 步骤 3 中的图像 1,3 Pioneer Steel Wheels Headphone Headband Replacement: 步骤 3 中的图像 2,3 Pioneer Steel Wheels Headphone Headband Replacement: 步骤 3 中的图像 3,3
    • Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
    • Repeat on the opposite side and the headband will be released.
    • During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
结论
Garrett Leung
于04/16/13注册
955 声望
创作了8篇指南
团队
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G40
4 名成员
创作了37篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 22
总计 1,177
