跳转到主内容
Pioneer MXT-X366BT Metal Case Replacement
你所需要的
  1. Pioneer MXT-X366BT Metal Case Replacement, Metal Casing: 步骤 1 中的图像 1,2 Pioneer MXT-X366BT Metal Case Replacement, Metal Casing: 步骤 1 中的图像 2,2
    • Apply small amount of pressure inward with a plastic opening tool to release bottom clip.
    • Pry the top clip with the plastic opening tool to release it.
    • The head unit is symmetrical and has the same amount of clips on the other side.
  2. Pioneer MXT-X366BT Metal Case Replacement: 步骤 2 中的图像 1,1
    • Remove the face plate holder.
  3. Pioneer MXT-X366BT Metal Case Replacement: 步骤 3 中的图像 1,1
    • Remove the six 5mm Phillips-head screws with Philips #2 screwdriver.
  4. Pioneer MXT-X366BT Metal Case Replacement: 步骤 4 中的图像 1,2 Pioneer MXT-X366BT Metal Case Replacement: 步骤 4 中的图像 2,2
    • Remove the inner three 5mm Phillips head screws, with a Phillips #2 screwdriver, attached to the metal backing.
    • Remove the metal backing that is now free.
  5. Pioneer MXT-X366BT Metal Case Replacement: 步骤 5 中的图像 1,1
    • Carefully slide the metal casing forward.
    • Metal piece standing is the rear of the head unit.
    • Edges are sharp.
  6. Pioneer MXT-X366BT Metal Case Replacement: 步骤 6 中的图像 1,1
    • Lift the metal casing from the rear and pull it away.
    • Edges are sharp.
  7. Pioneer MXT-X366BT Metal Case Replacement: 步骤 7 中的图像 1,1
    • The metal casing is now fully removed.
结论
另外一个人完成了本指南。
Blaine Kaiser
于03/22/18注册
169 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 281
