跳转到主内容
Pioneer FH-X730BS USB Port Replacement
你所需要的
  1. Pioneer FH-X730BS USB Port Replacement, Deck Buttons: 步骤 1 中的图像 1,3 Pioneer FH-X730BS USB Port Replacement, Deck Buttons: 步骤 1 中的图像 2,3 Pioneer FH-X730BS USB Port Replacement, Deck Buttons: 步骤 1 中的图像 3,3
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. Pioneer FH-X730BS USB Port Replacement: 步骤 2 中的图像 1,3 Pioneer FH-X730BS USB Port Replacement: 步骤 2 中的图像 2,3 Pioneer FH-X730BS USB Port Replacement: 步骤 2 中的图像 3,3
    • After removing the stereo face from the frame it should look similar to this.
    • Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
  3. Pioneer FH-X730BS USB Port Replacement: 步骤 3 中的图像 1,3 Pioneer FH-X730BS USB Port Replacement: 步骤 3 中的图像 2,3 Pioneer FH-X730BS USB Port Replacement: 步骤 3 中的图像 3,3
    • Remove the volume knob by pulling it towards you and pull the motherboard out of the face.
    • The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons.
    • You can now insert the replacement audio buttons into the face.
  4. Pioneer FH-X730BS USB Port Replacement, USB Port: 步骤 4 中的图像 1,1
    • Here you are able to desolder the USB ports from the circuit board and solder a replacement USB port on.
    • The end of the soldering iron will be hot.
结论
Cody Pesta
于09/17/18注册
688 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 1,194
