跳转到主内容
Pioneer Elite PRO-RO6U Power Supply Board Replacement
你所需要的
  1. Pioneer Elite PRO-RO6U Power Supply Board Replacement, Power Supply Board: 步骤 1 中的图像 1,1
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
  2. Pioneer Elite PRO-RO6U Power Supply Board Replacement: 步骤 2 中的图像 1,1
    • Remove the three 6.5 mm Phillips screws on the back of the device casing.
  3. Pioneer Elite PRO-RO6U Power Supply Board Replacement: 步骤 3 中的图像 1,1
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
  4. Pioneer Elite PRO-RO6U Power Supply Board Replacement: 步骤 4 中的图像 1,1
    • Gently pull upward and unplug cables D4 and D5.
  5. Pioneer Elite PRO-RO6U Power Supply Board Replacement: 步骤 5 中的图像 1,1
    • Remove the two 7/16 inch Phillips screws to the left and right of the power supply port.
    • Remove three 5/16 inch Phillips screws from the corners of the board.
  6. Pioneer Elite PRO-RO6U Power Supply Board Replacement: 步骤 6 中的图像 1,1
    • Remove the power supply board by pulling it toward the interior of the device then lifting.
结论
Cody Carter
于01/30/18注册
1,049 声望
创作了6篇指南
团队
Baylor, Team S1-G5, Johnson Spring 2018 Baylor, Team S1-G5, Johnson Spring 2018 的会员
BU-JOHNSON-S18S1G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 577
