跳转到主内容
Pioneer A1 XW-SMA1-K Antenna Replacement
你所需要的
  1. Pioneer A1 XW-SMA1-K Antenna Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Use the spudger to remove the mesh front panel.
  2. Pioneer A1 XW-SMA1-K Antenna Replacement: 步骤 2 中的图像 1,2 Pioneer A1 XW-SMA1-K Antenna Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the thirteen 12 mm screws in the speaker frame.
    • Remove the speaker frame by pulling vertically upwards revealing the motherboard.
  3. Pioneer A1 XW-SMA1-K Antenna Replacement: 步骤 3 中的图像 1,3 Pioneer A1 XW-SMA1-K Antenna Replacement: 步骤 3 中的图像 2,3 Pioneer A1 XW-SMA1-K Antenna Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the twelve 12 mm screws from the middle frame.
    • Remove the middle frame by pulling upward and vertically.
  4. Pioneer A1 XW-SMA1-K Antenna Replacement: 步骤 4 中的图像 1,2 Pioneer A1 XW-SMA1-K Antenna Replacement: 步骤 4 中的图像 2,2
    • Use the Phillips #1 screwdriver to remove the nine 12 mm screws from the motherboard.
    • Flip the motherboard over.
    • Remove the motherboard by detaching the antenna.
  5. Pioneer A1 XW-SMA1-K Antenna Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Remove the motherboard from the speaker.
  6. Pioneer A1 XW-SMA1-K Antenna Replacement, Antenna: 步骤 6 中的图像 1,2 Pioneer A1 XW-SMA1-K Antenna Replacement, Antenna: 步骤 6 中的图像 2,2
    • Flip over the back panel and pull the antenna up and out.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 535
