跳转到主内容
Pine64 PineTab 2 Touch & Front Glass Replacement
你所需要的
    • Shut your device off
    • Remove the SD-Card
  1. Pine64 PineTab 2 Touch & Front Glass Replacement, Unclip the front panel: 步骤 2 中的图像 1,1
    • Use the opening tool to lift the panel from the back cover
    • The panel is clipped to the frame so you should feel the clips release
    • Sliding the opening tool sideways after opening the first clips helps opening others
    • You will need to open clips on all 4 sides
  2. Pine64 PineTab 2 Touch & Front Glass Replacement, Open the device: 步骤 3 中的图像 1,1
    • Lift the panel out of the back and put it on a soft surface with the glass down without stretching the flex cable connecting the back and the mainboard
    • The element forming the three buttons will probably fall out at this point. Put it aside but remember to put it back into the back cover before closing the device
  3. Pine64 PineTab 2 Touch & Front Glass Replacement, Remove the wifi antenna: 步骤 4 中的图像 1,1
    • The wifi antenna is glued to the frame
    • Carefully peel it of without tearing it apart
    • It is sticky enough to hold again later without extra glue
  4. Pine64 PineTab 2 Touch & Front Glass Replacement, Remove the front camera and speakers: 步骤 5 中的图像 1,1
    • Unscrew the speaker (mounted at the top with metal surfaces)
    • Lift the front camera out of its hole. It has no screws or clips
    • Move those parts inwards so they rest on the back of the LCD
  5. Pine64 PineTab 2 Touch & Front Glass Replacement, Remove the back camera holder and headphone jack: 步骤 6 中的图像 1,2 Pine64 PineTab 2 Touch & Front Glass Replacement, Remove the back camera holder and headphone jack: 步骤 6 中的图像 2,2
    • Unscrew and lift aside the black plastic that holds the back camera in place
    • The camera itself can remain
    • Remove the washer screw holding the headphone jack in place (next to the camera)
  6. Pine64 PineTab 2 Touch & Front Glass Replacement, Remove the round sensor and free the speaker cables: 步骤 7 中的图像 1,1
    • Carefully lift the round sensor from its position in the frame
    • Remove the speaker cables from their trenches in the black support element, it may be covered by tape
    • Unscrew the element and put it aside
  7. Pine64 PineTab 2 Touch & Front Glass Replacement, Remove the touch connector flat cable: 步骤 8 中的图像 1,1
    • Remove the flat cable connecting the touch from the mainboard by flipping up the black latch holding it in place
  8. Pine64 PineTab 2 Touch & Front Glass Replacement, Unscrew the mainboard: 步骤 9 中的图像 1,1
    • Remove the screws holding the mainboard
    • Lift it up carefully to access the LCD clips underneath
  9. Pine64 PineTab 2 Touch & Front Glass Replacement, Remove the LCD from the front glass: 步骤 10 中的图像 1,1
    • Unclip the LCD panel from the front glass panel by carefully wedging an opening pick between the panel and the clips holding it in place
    • You can now swap the front glass and touch unit
    • The replacement unit has a protective foil on the inside. You need to remove that before installing the new glass
    • The foil started to leave residue on the glass so i used a hair dryer to weaken the glue
结论
Congratulations you now have a touch device again
Zehka
于01/09/22注册
231 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 19
总计 317
