跳转到主内容
Pine64 PinePhone Charging Port Replacement
你所需要的
  1. Pine64 PinePhone Charging Port Replacement, Back Cover: 步骤 1 中的图像 1,2 Pine64 PinePhone Charging Port Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Place the device face down on a non-scratch surface.
  2. Pine64 PinePhone Charging Port Replacement: 步骤 2 中的图像 1,1
    • Using a fingernail pry open the back cover off with the bottom left indent.
  3. Pine64 PinePhone Charging Port Replacement, Charging Port: 步骤 3 中的图像 1,3 Pine64 PinePhone Charging Port Replacement, Charging Port: 步骤 3 中的图像 2,3 Pine64 PinePhone Charging Port Replacement, Charging Port: 步骤 3 中的图像 3,3
    • Using a Phillips #000 screwdriver, remove each of the screws around the perimeter of the PinePhone.
    • Remove the battery.
  4. Pine64 PinePhone Charging Port Replacement: 步骤 4 中的图像 1,1
    • Remove the midframe from the phone.
  5. Pine64 PinePhone Charging Port Replacement: 步骤 5 中的图像 1,1
    • Carefully lift up the vibrator, connected to the board by two wires.
  6. Pine64 PinePhone Charging Port Replacement: 步骤 6 中的图像 1,1
    • Applying even pressure, lift up the board.
    • An adhesive is all that is keeping it to the frame of the phone, so there should be minimum resistance.
    • With a new adhesive strip, connect the replacement board to the frame. Make sure to secure the vibrator in the same place as the original.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 42
总计 1,051
