跳转到主内容
加入维修社区 - 创建账户
Pimax 5K Plus Disassembly
你所需要的
  1. Pimax 5K Plus Disassembly, Remove the facial interface: 步骤 1 中的图像 1,3 Pimax 5K Plus Disassembly, Remove the facial interface: 步骤 1 中的图像 2,3 Pimax 5K Plus Disassembly, Remove the facial interface: 步骤 1 中的图像 3,3
    • Carefully pull on the rubber surround.
    • Try not to put too much pressure anywhere on the plastic as it cracks easily, especially the large flat surface on the front.
  2. Pimax 5K Plus Disassembly, Unplug the PC Cable: 步骤 2 中的图像 1,3 Pimax 5K Plus Disassembly, Unplug the PC Cable: 步骤 2 中的图像 2,3 Pimax 5K Plus Disassembly, Unplug the PC Cable: 步骤 2 中的图像 3,3
    • Gently but firmly pull on the cable. Rotate around as you pull and it should come out easily.
  3. Pimax 5K Plus Disassembly, Remove the case screws: 步骤 3 中的图像 1,3 Pimax 5K Plus Disassembly, Remove the case screws: 步骤 3 中的图像 2,3 Pimax 5K Plus Disassembly, Remove the case screws: 步骤 3 中的图像 3,3
    • Pull out the four rubber pieces on the inside edge of the case screws.
    • Use a Phillips screwdriver to remove the four 5mm‑long machine screws holding together the case.
  4. Pimax 5K Plus Disassembly, Unclip the case: 步骤 4 中的图像 1,3 Pimax 5K Plus Disassembly, Unclip the case: 步骤 4 中的图像 2,3 Pimax 5K Plus Disassembly, Unclip the case: 步骤 4 中的图像 3,3
    • Use a pry tool to carefully pry open and unclip the edges of the headset.
    • Work your way around the headset. Be mindful that the plastic cracks fairly easily so try not to put too much pressure in a way that would cause it to crack or for existing cracks to grow
    • Be careful when reaching the end as there is a ribbon cable that connects to the front plastic and pulling too hard on it could damage it leading to less lighthouse sensors at best and a headset that won't initialize at worst.
    • If you're using a metal pry tool, be careful how you apply pressure. It can be easy to cosmetically ruin the edges of the plastic when prying. If this happens and leaves the plastic sharp you may wish to sand it down a bit so as to avoid future cuts.
  5. Pimax 5K Plus Disassembly: 步骤 5 中的图像 1,3 Pimax 5K Plus Disassembly: 步骤 5 中的图像 2,3 Pimax 5K Plus Disassembly: 步骤 5 中的图像 3,3
    • Carefully separate the two plastic halves without pulling on the ribbon cable.
  6. Pimax 5K Plus Disassembly, Remove the lighthouse ribbon cable: 步骤 6 中的图像 1,3 Pimax 5K Plus Disassembly, Remove the lighthouse ribbon cable: 步骤 6 中的图像 2,3 Pimax 5K Plus Disassembly, Remove the lighthouse ribbon cable: 步骤 6 中的图像 3,3
    • Use an angled tool to unlatch the ZIF connectors.
    • Gently pull out the ribbon cable. Due to the connectors being staggered you can't really have the cable out straight away from the headset.
    • Reassembly note: It's easier to start with the smaller ribbon cable here.
  7. Pimax 5K Plus Disassembly, Remove other ribbon cables: 步骤 7 中的图像 1,3 Pimax 5K Plus Disassembly, Remove other ribbon cables: 步骤 7 中的图像 2,3 Pimax 5K Plus Disassembly, Remove other ribbon cables: 步骤 7 中的图像 3,3
    • Remove the kapton tape from the ribbon cable connectors.
    • Disconnect the lightbar, display, and lighthouse ribbon connectors which the tape covered, and disconnect the top and bottom USB-C port ribbon cables.
    • If you don't want to open the eye tube, you dont need to disconnect the lightbar or display ribbon cables.
    • Carefully peel up the top and bottom USB-C ribbon cable ribbons from the metal display support, as they are glued on.
    • On reassembly, carefully make sure the ribbon cables are fully seated. These cables are double-row. If the white line isn't up against the edge of the connector, the contacts could make connection with the wrong pins.
  8. Pimax 5K Plus Disassembly, Optional steps note: 步骤 8 中的图像 1,2 Pimax 5K Plus Disassembly, Optional steps note: 步骤 8 中的图像 2,2
    • We will now be opening the left eye tube. This is the quickest way to get inside an eye tube. If you don't want to open the eye tubes, skip to Step 13.
    • The right eye tube requires taking it apart significantly further as you have to remove the motherboard.
  9. Pimax 5K Plus Disassembly, Remove eye tube screws: 步骤 9 中的图像 1,1
    • Use a Phillips screwdriver to remove the eight screws securing the metal display support.
    • Four 3mm-long silver plastic screws
    • Four 4mm-long black plastic screws (and metal bracket)
  10. Pimax 5K Plus Disassembly, Remove tape: 步骤 10 中的图像 1,3 Pimax 5K Plus Disassembly, Remove tape: 步骤 10 中的图像 2,3 Pimax 5K Plus Disassembly, Remove tape: 步骤 10 中的图像 3,3
    • Remove the strong support tape.
    • Remove the warranty void tape.
  11. Pimax 5K Plus Disassembly, Open eye tube: 步骤 11 中的图像 1,3 Pimax 5K Plus Disassembly, Open eye tube: 步骤 11 中的图像 2,3 Pimax 5K Plus Disassembly, Open eye tube: 步骤 11 中的图像 3,3
    • Lift up the metal display support bracket being mindful of the ribbon cable connecting to the display on the outer edge
    • Use a plastic spudger to lift up the on the display using the small hole near the corner
  12. Pimax 5K Plus Disassembly, Store the display: 步骤 12 中的图像 1,2 Pimax 5K Plus Disassembly, Store the display: 步骤 12 中的图像 2,2
    • Lift out the display.
    • Be sure to keep the display in a safe place. Ideally prevent dust from falling/collecting on it's surface, as that will be where it is the most visible in VR.
    • You now have access to the left eye tube!
  13. Pimax 5K Plus Disassembly, Remove the lens fabric: 步骤 13 中的图像 1,3 Pimax 5K Plus Disassembly, Remove the lens fabric: 步骤 13 中的图像 2,3 Pimax 5K Plus Disassembly, Remove the lens fabric: 步骤 13 中的图像 3,3
    • Use your fingernails or a tool to pull inward and outward on the top inner corner of the fabric-lined plastic around the lens to pull it off it's plastic clips.
    • Do the same on the bottom inner edge.
    • Now the whole inner side should be loose and have a bit of play in it.
    • If you're too rough with it, the fabric can become dislodged from the plastic ring it's attached to. If this happens, you should be able to glue it back into place once it's out.
  14. Pimax 5K Plus Disassembly: 步骤 14 中的图像 1,1
    • Keep the inner edge lifted, and use a fingernail or tool to pull outward on the outter edge of the fabric-lined plastic around the lens to free it from the longer outer plastic clips.
  15. Pimax 5K Plus Disassembly: 步骤 15 中的图像 1,2 Pimax 5K Plus Disassembly: 步骤 15 中的图像 2,2
    • Use a Phillips screwdriver to remove the ten 4mm-long machine screws holding on the outer fabric support ring.
    • Remove the surround fabric.
  16. Pimax 5K Plus Disassembly, Remove the inner asssembly: 步骤 16 中的图像 1,3 Pimax 5K Plus Disassembly, Remove the inner asssembly: 步骤 16 中的图像 2,3 Pimax 5K Plus Disassembly, Remove the inner asssembly: 步骤 16 中的图像 3,3
    • Use a Phillips screwdriver to remove the 14 screws securing the inner housing:
    • Eight recessed 4mm-long machine screws
    • Six 4mm-long plastic screws
    • Carefully pull out the inner assembly.
  17. Pimax 5K Plus Disassembly, Conclusion: 步骤 17 中的图像 1,2 Pimax 5K Plus Disassembly, Conclusion: 步骤 17 中的图像 2,2
    • Congratulations! You've pretty much disassembled a Pimax 5K Plus. This is as far as I'm going to take this guide, but the rest of the component removal is fairly straightforward and I'm confident you can figure it out.
    • Contributions are welcome if someone wants to finish this off.
结论
另外一个人完成了本指南。
othello7
于02/08/24注册
310 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 59
总计 928
