跳转到主内容
Pillow Stuffing Replacement
你所需要的
  1. Pillow Stuffing Replacement, Stuffing: 步骤 1 中的图像 1,1
    • Measure the length and width of the pillow to determine how much stuffing is needed.
    • A standard sleeping pillow is 20"x26", and will require 2 lbs of polyester fiber fill.
  2. Pillow Stuffing Replacement: 步骤 2 中的图像 1,1
    • With the seam ripper, create a 4-6 inch opening in the pillow about 2 inches from the corner.
    • To use the seam ripper: cut one stitch at a time using the sharp end. The red tip should remain upwards.
  3. Pillow Stuffing Replacement: 步骤 3 中的图像 1,2 Pillow Stuffing Replacement: 步骤 3 中的图像 2,2
    • Remove the existing stuffing from the pillow.
  4. Pillow Stuffing Replacement: 步骤 4 中的图像 1,3 Pillow Stuffing Replacement: 步骤 4 中的图像 2,3 Pillow Stuffing Replacement: 步骤 4 中的图像 3,3
    • Place a tennis ball-sized amount of new stuffing firmly into the 3 intact corners of the pillow.
    • This will help open up and stabilize the shell of the pillow to ensure even distribution of the stuffing.
    • Continue adding stuffing to the pillow to desired stiffness.
    • To ensure a smooth and regular shaped pillow, gently pull at the stuffing until it is fluffy before placing it into the pillow.
  5. Pillow Stuffing Replacement: 步骤 5 中的图像 1,2 Pillow Stuffing Replacement: 步骤 5 中的图像 2,2
    • Use the scissors to cut a length of thread approximately 24 inches long.
    • A dark thread is used here to maximize visibility. Typically, the thread would be matched with the color of the fabric.
    • Thread the needle and slide it to the center of the length of thread.
    • Triple knot the two loose ends together.
  6. Pillow Stuffing Replacement: 步骤 6 中的图像 1,3 Pillow Stuffing Replacement: 步骤 6 中的图像 2,3 Pillow Stuffing Replacement: 步骤 6 中的图像 3,3
    • Start a ladder stitch from the inside of the pillow by pulling the thread through the folded seam, right behind the opening that you created.
    • Make a small stitch through side of the opening.
    • Make an identical stitch directly across from your first stitch, on the opposite side of the opening. Pull the thread taut to begin the new seam.
    • Repeat, alternating from one side to the other until you have reached the end of the opening.
    • Be sure to keep each new stitch on the folds of the original seam.
  7. Pillow Stuffing Replacement: 步骤 7 中的图像 1,2 Pillow Stuffing Replacement: 步骤 7 中的图像 2,2
    • To compete the ladder stitch and close the pillow, pierce the needle through both sides of the seam and slowly pull the thread through until a loop is created.
    • Feed the needle through the loop and pull the thread tight.
    • Repeat this once more to ensure that the pillow is closed tightly, and cut off any excess thread with the scissors.
终点
1指南评论
Thanks for sharing. Informative post. Keep up the good work.
Hamptons Cushions
mitu seo - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 65
总计 3,708
