跳转到主内容
加入维修社区 - 创建账户
Picture Frame Matting Replacement
你所需要的
  1. Picture Frame Matting Replacement, Picture Frame Matting: 步骤 1 中的图像 1,1
    • Place the picture frame face down on a clean surface.
  2. Picture Frame Matting Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to rotate all of the frame’s backing clips away from the frame.
  3. Picture Frame Matting Replacement: 步骤 3 中的图像 1,2 Picture Frame Matting Replacement: 步骤 3 中的图像 2,2
    • Remove the backing by lifting it up and away using a spudger.
  4. Picture Frame Matting Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the picture and old matting from the frame.
    • You can leave the glass in the frame.
  5. Picture Frame Matting Replacement: 步骤 5 中的图像 1,1
    • Place the new matting into the frame and directly onto the glass.
    • Be careful while working around the glass to avoid self-injury or damaging the item.
  6. Picture Frame Matting Replacement: 步骤 6 中的图像 1,2 Picture Frame Matting Replacement: 步骤 6 中的图像 2,2
    • Position the picture properly and place it on the new matting.
    • Make sure there are no gaps between the edge of the picture and the matting.
    • Carefully place a couple of small pieces of clear tape on the picture and the new matting to hold it in place.
  7. Picture Frame Matting Replacement: 步骤 7 中的图像 1,1
    • Place the backing on top of the matting in the frame.
  8. Picture Frame Matting Replacement: 步骤 8 中的图像 1,2 Picture Frame Matting Replacement: 步骤 8 中的图像 2,2
    • Rotate the backing clips under the frame to secure it.
终点
Leah
于01/20/23注册
160 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 47
总计 605
