当前版本的文档还未经巡查,您可以查看最新的已查核版本。
拆解
这个拆解是不是维修指南。 要维修你的的Picstart Plus Development Programmer,请使用我们的维修手册。
这个步骤还没有翻译 帮忙翻译一下
Remove 4 Phillips screws located on the back side of the holding plate.
After the screws are removed, remove the case of the development programmer.
Carefully take out the circuit board with component side facing up. Put the case aside.
Disconnect the microcontroller module from the main board using a spudger or a similar tool.
Set the microcontroller module aside.
Flip over the mainboard so that the component side is facing down and remove the small Pan head screws that holds the cover of the IC holder
Remove the cover of the IC holder.
Remove the IC holder lever along with the small metal plate that covers the lever.
Set the lever and the lever cover aside.
Congratulations! You have completely dismantled the PICSTART Plus Development Programmer!
All the extracted components are shown in the picture.
与3其他贡献者
于11/17/13注册
656 声望
创作了2篇指南
徽章: 6
+ 3更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 2,398
