跳转到主内容
Photive Hydra Battery Replacement
你所需要的
  1. Photive Hydra Battery Replacement, Face Plate and Back Plate: 步骤 1 中的图像 1,1
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
  2. Photive Hydra Battery Replacement: 步骤 2 中的图像 1,2 Photive Hydra Battery Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry off the face plate.
  3. Photive Hydra Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
  4. Photive Hydra Battery Replacement: 步骤 4 中的图像 1,1
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
  5. Photive Hydra Battery Replacement: 步骤 5 中的图像 1,2 Photive Hydra Battery Replacement: 步骤 5 中的图像 2,2
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
  6. Photive Hydra Battery Replacement, Battery (Prerequisite): 步骤 6 中的图像 1,2 Photive Hydra Battery Replacement, Battery (Prerequisite): 步骤 6 中的图像 2,2
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
  7. Photive Hydra Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the ICR18650-26M battery from its position by pulling upwards and out of the casing.
  8. Photive Hydra Battery Replacement, Battery: 步骤 8 中的图像 1,1
    • identify the two points that will need soldering.
  9. Photive Hydra Battery Replacement: 步骤 9 中的图像 1,1
    • In this step you will perform the soldering to remove the positive(red) and negative(black) wires).
  10. Photive Hydra Battery Replacement: 步骤 10 中的图像 1,1
    • Once the solder is removed your battery is now removed and can be replaced with the new battery.
结论
Andrew Chase
于02/09/16注册
352 声望
创作了3篇指南
团队
USF Tampa, Team 11-3, Cheng Spring 2016 USF Tampa, Team 11-3, Cheng Spring 2016 的会员
USFT-CHENG-S16S11G3
5 名成员
创作了6篇指南
2条评论
Battery Replacement of the Photove Loudspeaker PH-BTW55
A very good description and easy to do, but: to replace a Battery to have to use a soldering iron is behind every tecnologie - must be „Made in China". Would I have know this on the first place I never would have bought this and I never will!
Rolf Luebbers - 回复
Why can’t you just cut the wires and then solder the cut wires together rather than de-soldering from the board?
Dan Bird - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 1,256
