跳转到主内容
Philips TAS7505 USB-A & USB-C port Replacement
你所需要的
  1. Philips TAS7505 USB-A & USB-C port Replacement, Philips TAS7505 Outer Shell Disassembly: 步骤 1 中的图像 1,2 Philips TAS7505 USB-A & USB-C port Replacement, Philips TAS7505 Outer Shell Disassembly: 步骤 1 中的图像 2,2
    • Make sure the speaker is turned off before you begin the disassembly.
    • Turn the speaker upside down. You will see a rubber base. Use an opening tool to lift up the sides to expose the screws.
  2. Philips TAS7505 USB-A & USB-C port Replacement: 步骤 2 中的图像 1,3 Philips TAS7505 USB-A & USB-C port Replacement: 步骤 2 中的图像 2,3 Philips TAS7505 USB-A & USB-C port Replacement: 步骤 2 中的图像 3,3
    • There will be 4 exposed screws. Make sure to use the Phillips #0 Screwdriver.
    • When the screws are removed, you can use an opening tool to take off the plastic cover.
  3. Philips TAS7505 USB-A & USB-C port Replacement: 步骤 3 中的图像 1,3 Philips TAS7505 USB-A & USB-C port Replacement: 步骤 3 中的图像 2,3 Philips TAS7505 USB-A & USB-C port Replacement: 步骤 3 中的图像 3,3
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with a Philips #0 screwdriver.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 USB-A & USB-C port Replacement: 步骤 4 中的图像 1,3 Philips TAS7505 USB-A & USB-C port Replacement: 步骤 4 中的图像 2,3 Philips TAS7505 USB-A & USB-C port Replacement: 步骤 4 中的图像 3,3
    • You can now see the inside of the speaker but you aren't done yet.
    • Remove both rubber stands that hold up the device horizontally (one of these stands is a cover for the USB ports).
  5. Philips TAS7505 USB-A & USB-C port Replacement: 步骤 5 中的图像 1,1
    • Once you pull these out, you can pull the whole sleeve to expose the infrastructure of the device.
  6. Philips TAS7505 USB-A & USB-C port Replacement, USB-A & USB-C port: 步骤 6 中的图像 1,1
    • Use the Phillips #0 Screwdriver to remove all 6 screws.
  7. Philips TAS7505 USB-A & USB-C port Replacement: 步骤 7 中的图像 1,1
    • Before pulling the USB port box out, disconnected the power connector from the motherboard.
    • Carefully pull out the USB port box
结论
Yamilena Hernandez
于09/26/22注册
135 声望
撰写一个指南
团队
CSU Los Angeles, Team 5-2, Adachi Fall 2022 CSU Los Angeles, Team 5-2, Adachi Fall 2022 的会员
CSULA-ADACHI-F22S5G2
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 144
