跳转到主内容
Philips TAS7505 Speaker Replacement
你所需要的
  1. Philips TAS7505 Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 Philips TAS7505 Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 Philips TAS7505 Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Using the opening tool, remove the rubber padding from the bottom of the speaker.
    • The rubber padding is glued on and may require reapplying adhesive to re-assemble.
  2. Philips TAS7505 Speaker Replacement: 步骤 2 中的图像 1,3 Philips TAS7505 Speaker Replacement: 步骤 2 中的图像 2,3 Philips TAS7505 Speaker Replacement: 步骤 2 中的图像 3,3
    • Using the Philips screwdriver head #0, remove all four screws holding the plastic plate in place.
    • Use the same opening tool from the previous step to remove the plastic plate.
  3. Philips TAS7505 Speaker Replacement: 步骤 3 中的图像 1,3 Philips TAS7505 Speaker Replacement: 步骤 3 中的图像 2,3 Philips TAS7505 Speaker Replacement: 步骤 3 中的图像 3,3
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with the Philips 0-bit screwdriver bit.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 Speaker Replacement: 步骤 4 中的图像 1,3 Philips TAS7505 Speaker Replacement: 步骤 4 中的图像 2,3 Philips TAS7505 Speaker Replacement: 步骤 4 中的图像 3,3
    • Squeeze the white connector on the bottom to release a clip that is hidden from sight. This will allow it to be wiggled free.
    • Remove the battery from the speaker by disconnecting the white connector from the motherboard.
  5. Philips TAS7505 Speaker Replacement: 步骤 5 中的图像 1,3 Philips TAS7505 Speaker Replacement: 步骤 5 中的图像 2,3 Philips TAS7505 Speaker Replacement: 步骤 5 中的图像 3,3
    • Find the rubber flap that covers the USB-A and USB-C port
    • Pull on the rubber flap, it should come out whole as shown in the second image
    • Once taken out the rubber flap, pull the interior of the speaker
  6. Philips TAS7505 Speaker Replacement: 步骤 6 中的图像 1,2 Philips TAS7505 Speaker Replacement: 步骤 6 中的图像 2,2
    • Once you have the speaker body out, unscrew the four screws holding the speaker down
    • Use Philips screwdriver head #0
  7. Philips TAS7505 Speaker Replacement: 步骤 7 中的图像 1,1
    • Pull the motherboard out then disconnect the white connector of the speaker by wiggling it back and forth.
    • See the motherboard repair guide for more in-depth instructions on this part
  8. Philips TAS7505 Speaker Replacement: 步骤 8 中的图像 1,3 Philips TAS7505 Speaker Replacement: 步骤 8 中的图像 2,3 Philips TAS7505 Speaker Replacement: 步骤 8 中的图像 3,3
    • The speaker will look like this if you have followed the steps correctly
结论
团队
CSU Los Angeles, Team 5-2, Adachi Fall 2022 CSU Los Angeles, Team 5-2, Adachi Fall 2022 的会员
CSULA-ADACHI-F22S5G2
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 28
总计 603
