跳转到主内容
Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement
你所需要的
  1. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: 步骤 1 中的图像 1,3 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: 步骤 1 中的图像 2,3 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: 步骤 1 中的图像 3,3
    • Pry the bottom cap away from the toothbrush body.
    • If it is not easy to open, these alternative instructions may help you.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
  2. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: 步骤 2 中的图像 1,2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: 步骤 2 中的图像 2,2
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
  3. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: 步骤 3 中的图像 1,2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: 步骤 3 中的图像 2,2
    • Slide the internal assembly out of the chassis.
  4. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Power Button, Mode Button: 步骤 4 中的图像 1,2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Power Button, Mode Button: 步骤 4 中的图像 2,2
    • Locate the power button (solder locations circled in orange).
    • Locate the mode button (solder locations circled in red).
    • Both buttons are attached by four soldered pins each.
  5. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: 步骤 5 中的图像 1,2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: 步骤 5 中的图像 2,2
    • Heat the soldering iron.
    • Soldering can cause burns and fires. Always solder in a well-ventilated area.
    • To test if the soldering iron is ready, place on the solder and if the solder melts easily and quickly, your soldering iron is ready.
    • Use the soldering iron to desolder all of the connections.
  6. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: 步骤 6 中的图像 1,2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: 步骤 6 中的图像 2,2
    • Use tweezers to remove the buttons from the board.
    • Place new button onto board and repeat previous steps in reverse to reassemble.
结论
Liam Casto
于04/01/24注册
354 声望
创作了3篇指南
团队
IUPUI, Team 1-4, Harley Spring 2024 IUPUI, Team 1-4, Harley Spring 2024 的会员
IUPUI-HARLEY-S24S1G4
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 56
总计 627
