跳转到主内容
Philips Sonicare Essence 1 Motherboard Replacement
你所需要的
  1. Philips Sonicare Essence 1  Motherboard Replacement, Brush Head: 步骤 1 中的图像 1,1
    • Place one hand on the toothbrush handle and one on the toothbrush head.
  2. Philips Sonicare Essence 1  Motherboard Replacement: 步骤 2 中的图像 1,1
    • Separate the toothbrush head from the body by twisting it in a counter-clockwise direction.
  3. Philips Sonicare Essence 1  Motherboard Replacement, Front Handle Panel: 步骤 3 中的图像 1,1
    • Insert the spudger along the seem at the top of the panel.
    • Begin to pry open the panel.
  4. Philips Sonicare Essence 1  Motherboard Replacement: 步骤 4 中的图像 1,1
    • Insert the plastic pick at the top of the seam that has already been slightly pried open.
    • Continue down the seam, prying the rest of the panel open with the spudger.
  5. Philips Sonicare Essence 1  Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Apply a soldering iron to the mount-connectors and copper-wire connectors until the motherboard can be removed.
  6. Philips Sonicare Essence 1  Motherboard Replacement: 步骤 6 中的图像 1,1
    • Lift the motherboard straight up.
结论
2等其他人完成本指南。
团队
IUPUI, Team S7-G1, Baechle Fall 2017 IUPUI, Team S7-G1, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S7G1
3 名成员
创作了6篇指南
2条评论
Great Guide!!!
vonwellon - 回复
Identification of the battery particulars would have been helpful to order replacement.
William Toperzer - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 14
总计 1,436
