跳转到主内容
Philips Sonicare DiamondClean Spring Replacement
你所需要的
  1. Philips Sonicare DiamondClean Spring Replacement, Spring: 步骤 1 中的图像 1,1
    • Pull the toothbrush head off the toothbrush.
  2. Philips Sonicare DiamondClean Spring Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Spring Replacement: 步骤 3 中的图像 1,3 Philips Sonicare DiamondClean Spring Replacement: 步骤 3 中的图像 2,3 Philips Sonicare DiamondClean Spring Replacement: 步骤 3 中的图像 3,3
    • Invert the toothbrush and apply pressure against the metal tip until the internals and casing separate.
    • Remove the internals from the casing.
  4. Philips Sonicare DiamondClean Spring Replacement: 步骤 4 中的图像 1,1
    • Remove the rubbers covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Spring Replacement: 步骤 5 中的图像 1,2 Philips Sonicare DiamondClean Spring Replacement: 步骤 5 中的图像 2,2
    • Separate the upper and lower components by sliding the circuit board section and motor section away from each other.
    • Remove the spring.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 100
总计 3,291
