Unplug the device and remove the purple guard.
  • Unplug the device and remove the purple guard.
  • Remove the head by pressing the right side of the head (with the device facing away from you).
  • You will hear a 'click' and the head will become dislodged from the body of the device.
添加评论
While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the  tensor clip.
  • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
  • Be careful not to lose the clip. It will likely fly off when it releases.
添加评论
  • The left side will swing down.
  • Remove the Tweezers.
添加评论
  • Remove the plastic component that swings down.
  • Use fingernails to lift clips from stubs.
添加评论
  • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
添加评论
  • Use a spudger to pry the gear housing unit from the base.
添加评论
  • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
添加评论
  • Replace Tweezer Head.
  • Ensure that the gear is inserted into the gear box end of the head.
  • When closing the head, make sure that the Tweezer is seated correctly. To check this, the tweezers should spin fairly easily with the finger.
添加评论
结论
另外一个人完成了本指南。
Nathan Christian
于2017年11月11日注册
440 信誉积分
创作了4篇指南
团队
IUPUI, Team S5-G5, Wilson Fall 2017 IUPUI, Team S5-G5, Wilson Fall 2017 的会员
IUPUI-WILSON-F17S5G5
3 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 15
总计 121
