跳转到主内容
Philips Satinelle Plastic Cover Replacement
你所需要的
  1. Philips Satinelle Plastic Cover Replacement, Plastic Cover: 步骤 1 中的图像 1,3 Philips Satinelle Plastic Cover Replacement, Plastic Cover: 步骤 1 中的图像 2,3 Philips Satinelle Plastic Cover Replacement, Plastic Cover: 步骤 1 中的图像 3,3
    • Remove the head by pushing it to the right.
  2. Philips Satinelle Plastic Cover Replacement: 步骤 2 中的图像 1,2 Philips Satinelle Plastic Cover Replacement: 步骤 2 中的图像 2,2
    • Use a metal spudger to pry open the casing.
    • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
  3. Philips Satinelle Plastic Cover Replacement: 步骤 3 中的图像 1,1
    • Pull the plastic casing apart with your hands.
    • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
结论
To reassemble your device, move the components from the broken shell into the new shell and follow these instructions in reverse order.
团队
Marist, Team S1-G1, Chaterdon Fall 2018 Marist, Team S1-G1, Chaterdon Fall 2018 的会员
MARS-CHATERDON-F18S1G1
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 536
