简介
Replace the epilator if the outer cover is so damaged that it becomes troublesome to hold. This is a very easy fix as it only requires you to transfer the components of the broken device into a new cover. You will need a metal spudger. Be careful not to damage any internal components as you pry apart the broken shell. This guide should take five to ten minutes to complete.
你所需要的
即将完成!
To reassemble your device, move the components from the broken shell into the new shell and follow these instructions in reverse order.
结论
