跳转到主内容
Philips Satinelle On/Off Switch Replacement
你所需要的
  1. Philips Satinelle On/Off Switch Replacement, Plastic Cover: 步骤 1 中的图像 1,3 Philips Satinelle On/Off Switch Replacement, Plastic Cover: 步骤 1 中的图像 2,3 Philips Satinelle On/Off Switch Replacement, Plastic Cover: 步骤 1 中的图像 3,3
    • Remove the head by pushing it to the right.
  2. Philips Satinelle On/Off Switch Replacement: 步骤 2 中的图像 1,2 Philips Satinelle On/Off Switch Replacement: 步骤 2 中的图像 2,2
    • Use a metal spudger to pry open the casing.
    • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
  3. Philips Satinelle On/Off Switch Replacement: 步骤 3 中的图像 1,1
    • Pull the plastic casing apart with your hands.
    • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
  4. Philips Satinelle On/Off Switch Replacement, On/Off Switch: 步骤 4 中的图像 1,1
    • Remove the green board and the black socket.
  5. Philips Satinelle On/Off Switch Replacement: 步骤 5 中的图像 1,1
    • Slide the switch down toward the socket.
  6. Philips Satinelle On/Off Switch Replacement: 步骤 6 中的图像 1,3 Philips Satinelle On/Off Switch Replacement: 步骤 6 中的图像 2,3 Philips Satinelle On/Off Switch Replacement: 步骤 6 中的图像 3,3
    • Put the components back into the frame
    • If the switch won't line up with the plastic square, make sure the large switch on the front of the operator is in the "off" position.
结论
另外一个人完成了本指南。
Riannon Varney
于10/08/18注册
168 声望
撰写一个指南
团队
Marist, Team S1-G1, Chaterdon Fall 2018 Marist, Team S1-G1, Chaterdon Fall 2018 的会员
MARS-CHATERDON-F18S1G1
3 名成员
创作了8篇指南
一条评论
Very precise instructions, thanks!
carlos - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 23
总计 1,689
