跳转到主内容
Philips SBA1060 Speaker Replacement
你所需要的
  1. Philips SBA1060 Speaker Replacement, Battery Casing: 步骤 1 中的图像 1,1
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Philips SBA1060 Speaker Replacement: 步骤 2 中的图像 1,3 Philips SBA1060 Speaker Replacement: 步骤 2 中的图像 2,3 Philips SBA1060 Speaker Replacement: 步骤 2 中的图像 3,3
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Philips SBA1060 Speaker Replacement: 步骤 3 中的图像 1,2 Philips SBA1060 Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
  4. Philips SBA1060 Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 Philips SBA1060 Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
    • Remove the circuit board by unscrewing the two interior screws located on the circuit board.
    • Pull out the battery plugs from the circuit board by pulling out the plugs to fully remove the back panel from the rest of the speaker.
  5. Philips SBA1060 Speaker Replacement: 步骤 5 中的图像 1,2 Philips SBA1060 Speaker Replacement: 步骤 5 中的图像 2,2
    • Locate the speaker needing replacing.
    • Remove the one screw holding the speaker in place with a PH0 size philips head screw driver.
  6. Philips SBA1060 Speaker Replacement: 步骤 6 中的图像 1,3 Philips SBA1060 Speaker Replacement: 步骤 6 中的图像 2,3 Philips SBA1060 Speaker Replacement: 步骤 6 中的图像 3,3
    • Score the glue that is holding the speaker in place with the spudger, and use your hands to pry off the speaker.
  7. Philips SBA1060 Speaker Replacement: 步骤 7 中的图像 1,2 Philips SBA1060 Speaker Replacement: 步骤 7 中的图像 2,2
    • Using a non-conductive glue, carefully seal the speaker to the casing.
    • Follow the glue instructions as set by the manufacturers. Let the glue set the appropriate amount of time.
    • Reassemble the device
结论
另外一个人完成了本指南。
April Driscoll
于10/21/13注册
321 声望
创作了3篇指南
团队
Clemson, Team 14-4, Benson Fall 2013 Clemson, Team 14-4, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G4
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 18
总计 1,704
