跳转到主内容
Philips SBA1060 Circuit Board Replacement
你所需要的
  1. Philips SBA1060 Circuit Board Replacement, Battery Casing: 步骤 1 中的图像 1,1
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Philips SBA1060 Circuit Board Replacement: 步骤 2 中的图像 1,3 Philips SBA1060 Circuit Board Replacement: 步骤 2 中的图像 2,3 Philips SBA1060 Circuit Board Replacement: 步骤 2 中的图像 3,3
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Philips SBA1060 Circuit Board Replacement: 步骤 3 中的图像 1,2 Philips SBA1060 Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
  4. Philips SBA1060 Circuit Board Replacement, Circuit Board: 步骤 4 中的图像 1,1
    • Remove the two screws on opposite ends of the circuit board with the PH0 size philips head screw driver.
    • Remove the damaged circuit board from the device.
  5. Philips SBA1060 Circuit Board Replacement: 步骤 5 中的图像 1,2 Philips SBA1060 Circuit Board Replacement: 步骤 5 中的图像 2,2
    • Remove the battery plug from the circuit board by pulling out the plugs to fully remove back panel.
    • Remove the speaker plugs from the circuit board by pulling out the plugs. They are located on opposite sides of the circuit board.
    • NOTE: When reassembling, note that the speaker with the red wire goes to the red plug, and the speaker with the white wire goes to the adjacent white plug.
    • Remove the light plug from the circuit board.
    • NOTE: This plug is twice as wide as the speaker and battery plugs.
    • Reassemble the device.
结论
2等其他人完成本指南。
April Driscoll
于10/21/13注册
321 声望
创作了3篇指南
团队
Clemson, Team 14-4, Benson Fall 2013 Clemson, Team 14-4, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G4
3 名成员
创作了4篇指南
2条评论
Is that one of those cheap pam amps that run from 5v?
fabio souza jr - 回复
Nice picture,it helps a lot in trouble shooting !
sergio - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 17
总计 1,316
