当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
From the Diagnostics Menu, select Touch Screen Calibration. The Calibrate Touch Screen screen is displayed.
Follow the steps shown. Press on the middle of each target with a blunt, narrow object.
NOTE: If the Touch Screen Calibration button does not respond, press the Accept button on the navigation ring to begin
If the calibration is not successful, have the ventilator serviced.
这个步骤还没有翻译 帮忙翻译一下
Disconnect these cables from the UI PCBA: • Switch PCBA cable • Nav-ring cable • Power switch overlay cable • Touch screen cable
Remove the switch PCBA.
Remove the screw that attaches the cable clamp to the LCD tray.
Remove the screws and washers that attach the LCD tray to the front bezel, then remove the LCD tray.
Remove the touch screen from the front bezel.
