跳转到主内容
Philips Respironics V60 Touchscreen Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
  1. Philips Respironics V60 Touchscreen Replacement, Touchscreen: 步骤 1 中的图像 1,1
    • From the Diagnostics Menu, select Touch Screen Calibration. The Calibrate Touch Screen screen is displayed.
    • Follow the steps shown. Press on the middle of each target with a blunt, narrow object.
    • NOTE: If the Touch Screen Calibration button does not respond, press the Accept button on the navigation ring to begin
    • If the calibration is not successful, have the ventilator serviced.
  2. Philips Respironics V60 Touchscreen Replacement: 步骤 2 中的图像 1,1
    • Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
    • Select Ventilator Shutdown, which will shut down the ventilator.
    • Improper shutdown may cause a Power has been restored message the next time the ventilator is turned on.
  3. Philips Respironics V60 Touchscreen Replacement: 步骤 3 中的图像 1,1
    • Remove the screws from the end cap and remove the end cap.
    • Remove the screws from the rear bezel.
    • Separate the front and rear bezel.
  4. Philips Respironics V60 Touchscreen Replacement: 步骤 4 中的图像 1,1
    • Disconnect these cables from the UI PCBA: • Switch PCBA cable • Nav-ring cable • Power switch overlay cable • Touch screen cable
    • Remove the switch PCBA.
    • Remove the screw that attaches the cable clamp to the LCD tray.
    • Remove the screws and washers that attach the LCD tray to the front bezel, then remove the LCD tray.
    • Remove the touch screen from the front bezel.
结论
Weihan Du
于04/11/20注册
241 声望
创作了2篇指南
团队
Cal Poly, Team S7-G10, Paton Spring 2020 Cal Poly, Team S7-G10, Paton Spring 2020 的会员
CPSU-PATON-S20S7G10
2 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 48
总计 1,989
