本指南有最近更改,您可查看未经巡查的最新版本。
简介
If there has been damage done to the top cover of the Philips Respironics V60 ventilator, this guide will help you replace it.
The top cover just simply serves as a cover for the inside of the ventilator, making sure that the parts of the ventilator within are protected. Damage to this could also damage the inside of the ventilator so it would be good to replace/repair it as quickly as possible.
你所需要的
Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
Select Ventilator Shutdown, which will shut down the ventilator.
Turn the captive D-ring fastener on the bottom of the panel counter-clockwise one-quarter turn and release.
Then remove the right side panel.
