跳转到主内容
Philips Respironics V200 Esprit Oxygen Valve Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. Philips Respironics V200 Esprit Oxygen Valve Replacement, Oxygen Valve: 步骤 1 中的图像 1,1
    • Before replacing the oxygen valve assembly:
    • You must install the oxygen regulator assembly before reinstalling the oxygen valve assembly
    • When reinstalling the oxygen valve, make sure the oxygen regulator and oxygen flow sensor are fully installed to the oxygen valve assembly
    • Always inspect the O-rings between interconnecting parts, and replace them if they are visibly damaged or rough to the touch.
    • Always use new O-rings supplied with replacement parts
    • Lightly lubricate O-rings with Krytox GPL226 lubricant when installing, and relubricate at every reinstallation
  2. Philips Respironics V200 Esprit Oxygen Valve Replacement: 步骤 2 中的图像 1,1
    • Remove the oxygen flow sensor
    • (Instructions found in Chapter 10.26 of the Respironics V200/Esprit Ventilator Service Manual.)
    • Careful! Do not cut the tie wrap or disconnect the O2 F/S cable from the flow sensor.
  3. Philips Respironics V200 Esprit Oxygen Valve Replacement: 步骤 3 中的图像 1,1
    • Remove the air flow sensor
    • (Instructions found in Chapter 10.27 of the Respironics V200/Esprit Ventilator Service Manual.)
    • Careful! Do not cut the tie wrap or disconnect the AIR F/S cable from the flow sensor.
  4. Philips Respironics V200 Esprit Oxygen Valve Replacement: 步骤 4 中的图像 1,1
    • Remove the air valve assembly
    • (Instructions found in Chapter 10.30 of the Respironics V200/Esprit Ventilator Service Manual.)
    • Disconnect the two MTR O2 cables on the oxygen valve from the mating MTR O2 cable
    • Disconnect the CROSS SOL cable from the crossover solenoid valve
    • Using a 8-mm socket with extension, remove the three bolts that hold the oxygen valve bracket
    • Slowly pull the oxygen valve assembly away from the oxygen regulator
结论
Grace Gius
于05/04/20注册
505 声望
创作了3篇指南
团队
Cal Poly, Team S1-G4, Zimmerman Spring 2020 Cal Poly, Team S1-G4, Zimmerman Spring 2020 的会员
CPSU-ZIMMERMAN-S20S1G4
5 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 403
