跳转到主内容
Philips Respironics V200 Esprit Oxygen Inlet Filter Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. Philips Respironics V200 Esprit Oxygen Inlet Filter Replacement, Oxygen Inlet Filter: 步骤 1 中的图像 1,1
    • Turn off the device.
    • On/Off switch located on the Front Panel as seen in Figure 8-2 (from the Operator Manual).
    • Disconnect from AC power.
  2. Philips Respironics V200 Esprit Oxygen Inlet Filter Replacement: 步骤 3 中的图像 1,1
    • Disconnect the oxygen hose.
    • Oxygen hose is connected to the Inlet Connector (section 14 of Figure 5-1, diagram from Operator Manual).
  3. Philips Respironics V200 Esprit Oxygen Inlet Filter Replacement: 步骤 4 中的图像 1,2 Philips Respironics V200 Esprit Oxygen Inlet Filter Replacement: 步骤 4 中的图像 2,2
    • Unscrew the water trap bowl (page 10-5 in Service Manual).
    • Located on the back panel of the ventilator (section 15 of Figure 5-1 from Operator Manual).
  4. Philips Respironics V200 Esprit Oxygen Inlet Filter Replacement: 步骤 5 中的图像 1,1
    • Separate the filter element from the black plastic retainer (page 10-5 of Service Manual).
    • Attach new filter element to the black plastic retainer (page 10-5 of Service Manual).
    • Reconnect the oxygen hose.
    • According to page 2-2 of the Operators Manual, care in the routing of the oxygen inlet hose should be exercised to ensure it is not exposed to mechanisms that could cause damage by cutting or heating/melting.
结论
  • Reconnect to AC Power.
  • To reassemble your device, follow these instructions in reverse order.
Grace Gius
于05/04/20注册
505 声望
创作了3篇指南
团队
Cal Poly, Team S1-G4, Zimmerman Spring 2020 Cal Poly, Team S1-G4, Zimmerman Spring 2020 的会员
CPSU-ZIMMERMAN-S20S1G4
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 274
