跳转到主内容
Philips Respironics System One REMstar Circuit Board Replacement
你所需要的
  1. Philips Respironics System One REMstar Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 1,1
    • Turn the device upside down so that the rubber feet are facing you.
    • Use a Torx TR15 screwdriver to remove the two 46.5mm screws located on the back.
    • Gently separate the panel so the wires are not damaged.
  2. Philips Respironics System One REMstar Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Using a Torx TR10 screwdriver, remove the seven 13.5 mm screws that are securing the inner casing.
    • Lift out the inner casing.
  3. Philips Respironics System One REMstar Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Remove the motor from the bottom portion of the casing and set it aside.
  4. Philips Respironics System One REMstar Circuit Board Replacement: 步骤 4 中的图像 1,2 Philips Respironics System One REMstar Circuit Board Replacement: 步骤 4 中的图像 2,2
    • Remove the side panel by lifting it up out of the base.
    • Remove the grouped wire and wire connector.
  5. Philips Respironics System One REMstar Circuit Board Replacement: 步骤 5 中的图像 1,2 Philips Respironics System One REMstar Circuit Board Replacement: 步骤 5 中的图像 2,2
    • Remove the circular piece by popping it off to separate the circuit board from the top cover.
    • No tools should be necessary to complete this action.
  6. Philips Respironics System One REMstar Circuit Board Replacement: 步骤 6 中的图像 1,2 Philips Respironics System One REMstar Circuit Board Replacement: 步骤 6 中的图像 2,2
    • Separate the green, red, and white wire connectors from their connections on the circuit board.
结论
2条评论
Do you happen to have a part number or link for replacement pcb?
Kyle Pierce - 回复
Ce anume nu funcționează ?
Mircea Crisan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 17
总计 979
