跳转到主内容
Philips Respironics System One REMstar Blower Unit Replacement
你所需要的
  1. Philips Respironics System One REMstar Blower Unit Replacement, Blower Unit: 步骤 1 中的图像 1,1
    • Turn the device upside down so that the rubber feet are facing you.
    • Use the TR15 screw head to remove the two 46.5mm length crews located on the back.
    • Gently remove the casing so that the wires are not damaged.
  2. Philips Respironics System One REMstar Blower Unit Replacement: 步骤 2 中的图像 1,1
    • Using a Torx TR10 screwdriver, remove the seven 13.5 mm screws that are securing the inner casing.
    • Remove the inner casing.
  3. Philips Respironics System One REMstar Blower Unit Replacement: 步骤 3 中的图像 1,1
    • Remove the motor from the bottom half of the inner casing and set it to the side.
  4. Philips Respironics System One REMstar Blower Unit Replacement: 步骤 4 中的图像 1,2 Philips Respironics System One REMstar Blower Unit Replacement: 步骤 4 中的图像 2,2
    • Remove the circular piece by popping it off to separate the circuit board from the top cover.
    • No tools should be necessary to complete this action.
  5. Philips Respironics System One REMstar Blower Unit Replacement: 步骤 5 中的图像 1,2 Philips Respironics System One REMstar Blower Unit Replacement: 步骤 5 中的图像 2,2
    • Disconnect the green and red wire connectors from their white connectors to disconnect the blower motor.
结论
2等其他人完成本指南。
一条评论
These steps may be out of sequential order. Step 4 should probably be Step 1 and perhaps some are even missing.
Charles Marshall - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 1,228
