跳转到主内容
简介
If you have a Philips Norleco face shaver and are noticing that it is becoming less effective, you may need to replace the shaving head blades with new ones. These heads contain small blades that dull over time. Philips Norelco recommends they be replaced every 12 months. In this guide I will show you how to install your new replacement blades.
  1. Begin by pressing the small button beneath the head to allow it to open. Begin by pressing the small button beneath the head to allow it to open.
    • Begin by pressing the small button beneath the head to allow it to open.
  2. Grasp the sides of the head and pull straight up to detach it from the body. Grasp the sides of the head and pull straight up to detach it from the body.
    • Grasp the sides of the head and pull straight up to detach it from the body.
  3. To unlock, rotate the center locking mechanism counter-clockwise. To unlock, rotate the center locking mechanism counter-clockwise.
    • To unlock, rotate the center locking mechanism counter-clockwise.
  4. Lift the locking mechanism straight up, freeing the blades.
    • Lift the locking mechanism straight up, freeing the blades.
  5. Carefully push the blades out from behind. Although the blades are covered, they can fall apart, exposing sharp edges. Always use care when handling. Although the blades are covered, they can fall apart, exposing sharp edges. Always use care when handling.
    • Carefully push the blades out from behind.
    • Although the blades are covered, they can fall apart, exposing sharp edges. Always use care when handling.
  6. Insert the new blades, making sure to face the side with the two tabs towards the center of the head. Although the blades are covered, they can fall apart, exposing sharp edges. Always use care when handling. Although the blades are covered, they can fall apart, exposing sharp edges. Always use care when handling.
    • Insert the new blades, making sure to face the side with the two tabs towards the center of the head.
  7. Line up the locking mechanism with the new blades, then rotate the center clockwise to lock down. Line up the locking mechanism with the new blades, then rotate the center clockwise to lock down. Line up the locking mechanism with the new blades, then rotate the center clockwise to lock down.
    • Line up the locking mechanism with the new blades, then rotate the center clockwise to lock down.
  8. Push the head back onto the body, then close it up. Your shaver is good to go! Push the head back onto the body, then close it up. Your shaver is good to go! Push the head back onto the body, then close it up. Your shaver is good to go!
    • Push the head back onto the body, then close it up. Your shaver is good to go!
终点
10等其他人完成本指南。
Austin Fisher
于2015年09月29日注册
356 信誉积分
撰写一个指南
团队
Cal Poly, Team 10-1, Green Fall 2015 Cal Poly, Team 10-1, Green Fall 2015 的会员
CPSU-GREEN-F15S10G1
4 名成员
创作了5篇指南
2条评论
This is a good guide thank you.
Replacing these shaver batteries would be a good guide: does anyone know how to do this?
Richard - 回复
Very well done - better than a video because you don’t need to continually stop, restart and rewind to catch specific details.
Clif T - 回复
添加评论
浏览统计数据:
过去的24小时: 17
过去的7天: 119
过去的30天: 545
总计 28,734
