跳转到主内容
Philips Norelco OneBlade Servo Motor Replacement
你所需要的
  1. Philips Norelco OneBlade Servo Motor Replacement, Servo Motor: 步骤 1 中的图像 1,3 Philips Norelco OneBlade Servo Motor Replacement, Servo Motor: 步骤 1 中的图像 2,3 Philips Norelco OneBlade Servo Motor Replacement, Servo Motor: 步骤 1 中的图像 3,3
    • Ensure razor is off and razor blade has been removed.
  2. Philips Norelco OneBlade Servo Motor Replacement: 步骤 2 中的图像 1,2 Philips Norelco OneBlade Servo Motor Replacement: 步骤 2 中的图像 2,2
    • Locate crease in bottom third of razor.
    • Hold razor in both hands, and place thumbs near crease.
    • Slightly bend the razor near crease.
    • Pull casing apart.
    • Device may turn on upon removal. Turn off razor before continuing.
  3. Philips Norelco OneBlade Servo Motor Replacement: 步骤 3 中的图像 1,3 Philips Norelco OneBlade Servo Motor Replacement: 步骤 3 中的图像 2,3 Philips Norelco OneBlade Servo Motor Replacement: 步骤 3 中的图像 3,3
    • Locate wires below motor on either side of circuit board.
    • Remove solder from each joint using solder removal kit.
    • Do not attempt to remove wires by force.
  4. Philips Norelco OneBlade Servo Motor Replacement: 步骤 4 中的图像 1,1
    • Remove new motor from package and place in position.
    • Motor should sit above circuit board with connection prongs facing downward. Additionally, center extrusion on bottom of motor should sit in provided hole.
结论
Please dispose of servo motor properly. For recycling information, please contact your local waste management facilities or visit www.recycle.philips.com
5等其他人完成本指南。
团队
IUPUI, Team S3-G3, Harley Fall 2017 IUPUI, Team S3-G3, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S3G3
3 名成员
创作了3篇指南
10条评论
does removing the motor exposing the battery? In my unit I see some green thing underneath the motor, looks like a AA battery, can you confirm?
or is it from somewhere else? (I need to replace my battery)
Yarden Cohen - 回复
I just dismantled my shaver, and it has a 1.2v AA size NiMH battery (suppo hsy aa1200).
João Paulo Gomes -
I’m also curious about the battery. Any one have pictures of it or know what kind of battery it has inside?
James Almeida - 回复
João Paulo Gomes -
Thanks! This definitely helps.
James Almeida -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 99
总计 19,060
