跳转到主内容
Philips Norelco MultiGroom 3100 Battery Replacement
你所需要的
  1. Philips Norelco MultiGroom 3100 Battery  Replacement, Power Button: 步骤 1 中的图像 1,1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco MultiGroom 3100 Battery  Replacement: 步骤 2 中的图像 1,2 Philips Norelco MultiGroom 3100 Battery  Replacement: 步骤 2 中的图像 2,2
    • Grip the attachment and twist it counterclockwise until you hear a click.
    • Pull the attachment up to remove it from the trimmer.
  3. Philips Norelco MultiGroom 3100 Battery  Replacement: 步骤 3 中的图像 1,2 Philips Norelco MultiGroom 3100 Battery  Replacement: 步骤 3 中的图像 2,2
    • Hold the trimmer upright so it is facing you.
    • Insert the plastic opening tool in the gap at the top of the power button.
  4. Philips Norelco MultiGroom 3100 Battery  Replacement: 步骤 4 中的图像 1,1
    • Apply pressure to pry off the power button.
  5. Philips Norelco MultiGroom 3100 Battery  Replacement, Casing: 步骤 5 中的图像 1,2 Philips Norelco MultiGroom 3100 Battery  Replacement, Casing: 步骤 5 中的图像 2,2
    • Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
    • Separate the bezel one clip at a time so that the clips do not break.
  6. Philips Norelco MultiGroom 3100 Battery  Replacement: 步骤 6 中的图像 1,2 Philips Norelco MultiGroom 3100 Battery  Replacement: 步骤 6 中的图像 2,2
    • Insert the spudger in the indicated hole and apply a tilting force to loosen the outer casing.
    • Pull upward on the top of the inner housing to remove it from the outer casing.
  7. Philips Norelco MultiGroom 3100 Battery  Replacement, Battery: 步骤 7 中的图像 1,1
    • Grab the upper casing firmly and pull to seperate from lower casing.
    • This will require some force and may separate suddenly.
  8. Philips Norelco MultiGroom 3100 Battery  Replacement: 步骤 8 中的图像 1,1
    • Once upper casing is removed, use plastic spudger and insert into the side tabs to free battery casing.
    • Once tabs are freed, pull battery casing from upper casing.
    • Upper casing will not separate from tab separation alone, removal will still require manipulation by hand.
  9. Philips Norelco MultiGroom 3100 Battery  Replacement: 步骤 9 中的图像 1,1
    • Insert plastic spudger into battery brackets individually. "Wiggle" the bracket out of place
    • Be careful to not bend bracket severely --brackets will need to fit back into place later.
  10. Philips Norelco MultiGroom 3100 Battery  Replacement: 步骤 10 中的图像 1,1
    • Use a soldering gun and apply heat to the battery contact tabs until solder is malleable.
    • Once solder is malleable, carefully insert a plastic spudger beneath the tab and over the battery to pry battery away from the contact tab.
    • Use proper safety equipment when operating a soldering gun, as burns can occur. Gloves and eye protection recommended.
  11. Philips Norelco MultiGroom 3100 Battery  Replacement: 步骤 11 中的图像 1,1
    • Once contact tabs have been removed from the battery, the battery can now be removed by hand or by use of a plastic spudger.
    • Locate new battery and prepare for soldering in next step.
  12. Philips Norelco MultiGroom 3100 Battery  Replacement: 步骤 12 中的图像 1,1
    • Make sure battery is safely secured and re-solder the battery contact tab onto new battery.
    • Check that contact tab is re-soldered onto the original solder.
    • Once solder is dried and cool, toggle the power switch (not the power button) to check that the device is functional.
    • Make sure solder adequately covers the contact tab so the solder will not break in the future
    • Solder with caution. Use gloves and eye protection. Solder contains lead, work in a properly ventilated area.
终点
15等其他人完成本指南。
Mahmoud
于09/05/17注册
101 声望
撰写一个指南
团队
IUPUI, Team S1-G5, Freund Fall 2017 IUPUI, Team S1-G5, Freund Fall 2017 的会员
IUPUI-FREUND-F17S1G5
4 名成员
创作了1篇指南
10条评论
Capitalize Battery in the Title
Go ahead and upload the picture of the device.
Be sure to submit to iFixit for their comments when done.
Linda Freund - 回复
Also include prerequisite guides
Linda Freund - 回复
For the Multigroom QG3380 (which I bought at Costco in Canada), there are some differences. Don’t remove the power button – not needed. Pry off the silver frame – very hard not to break some clips. It uses two 750 mAh AAA NiMH batteries (Suppo HSY-AAA0). I’ve ordered 900 mAh batteries with clips to replace these.
Brian Panhuyzen - 回复
Where did you order the replacement batteries ?
Ferdinando Anceschi -
I had mine from Japan, QG3380 too many clips broke off and indeed don’t remove the power button on that one.
alexander_binder -
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 47
过去 30 天: 175
总计 29,703
