跳转到主内容
Philips Norelco BeardTrimmer 3100 Power Switch Replacement
你所需要的
  1. Philips Norelco BeardTrimmer 3100 Power Switch Replacement, Front and Back Panels: 步骤 1 中的图像 1,1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 2 中的图像 1,2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 2 中的图像 2,2
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 3 中的图像 1,2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 3 中的图像 2,2
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 4 中的图像 1,3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 4 中的图像 2,3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 4 中的图像 3,3
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 5 中的图像 1,3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 5 中的图像 2,3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 5 中的图像 3,3
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 6 中的图像 1,2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 6 中的图像 2,2
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 7 中的图像 1,1
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 8 中的图像 1,2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 8 中的图像 2,2
  9. Philips Norelco BeardTrimmer 3100 Power Switch Replacement, Power Switch: 步骤 9 中的图像 1,1
    • Remove the front panel completely from the rest of the beard trimmer.
  10. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 10 中的图像 1,1
    • Rotate the front panel so that the power switch is facing away from you.
  11. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 11 中的图像 1,3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 11 中的图像 2,3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 11 中的图像 3,3
    • Push the white plastic frame upward to remove it from the notch.
    • Pull the white plastic frame off the front panel of the beard trimmer.
  12. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 步骤 12 中的图像 1,1
    • Remove the power switch from the front panel once the white plastic frame is removed.
结论
Tamara Titus
于09/03/15注册
133 声望
撰写一个指南
团队
USF Tampa, Team 15-2, Blackwell Fall 2015 USF Tampa, Team 15-2, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S15G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 39
总计 5,889
