跳转到主内容
Philips Norelco BeardTrimmer 3100 Battery Replacement
你所需要的
  1. Philips Norelco BeardTrimmer 3100 Battery Replacement, Front and Back Panels: 步骤 1 中的图像 1,1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 2 中的图像 1,2 Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 2 中的图像 2,2
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 3 中的图像 1,2 Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 3 中的图像 2,2
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 4 中的图像 1,3 Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 4 中的图像 2,3 Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 4 中的图像 3,3
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 5 中的图像 1,3 Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 5 中的图像 2,3 Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 5 中的图像 3,3
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 6 中的图像 1,2 Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 6 中的图像 2,2
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 7 中的图像 1,1
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 8 中的图像 1,2 Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 8 中的图像 2,2
  9. Philips Norelco BeardTrimmer 3100 Battery Replacement, Battery: 步骤 9 中的图像 1,3 Philips Norelco BeardTrimmer 3100 Battery Replacement, Battery: 步骤 9 中的图像 2,3 Philips Norelco BeardTrimmer 3100 Battery Replacement, Battery: 步骤 9 中的图像 3,3
    • Face the battery towards you.
    • Locate the power connectors on the bottom of the trimmer, pull them from the base with your spudger.
  10. Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 10 中的图像 1,1
    • Grab the battery by its sides, pull it upwards out of the base of the trimmer.
  11. Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 11 中的图像 1,2 Philips Norelco BeardTrimmer 3100 Battery Replacement: 步骤 11 中的图像 2,2
    • Locate the connection between the blue wire and the battery. Melt the solder and completely remove the battery.
    • Be careful when dealing with solder. The metals will become very hot and can cause damage to skin/clothing.
结论
29等其他人完成本指南。
Darren Chu
于09/03/15注册
1,605 声望
创作了3篇指南
团队
USF Tampa, Team 15-2, Blackwell Fall 2015 USF Tampa, Team 15-2, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S15G2
4 名成员
创作了8篇指南
20条评论
Hi, what are the specs on the NiMh battery?
Eric Nguyen - 回复
NiMh AA 1650 mAh 1.2V rechargeable battery. Search Amazon.com for philips norelco qt4022 battery. One result is UPC 737212062822
galligant -
I think you can simply use a AA battery, 1.2V
Olivier Lefaux - 回复
Note: AA Alkaline battery is 1.5V and not rechargeable.
galligant -
Awesome work.very helpful
Himanshu sahrma - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 40
过去 30 天: 223
总计 70,961
